2009-10-20, 23:17
Pages: 1 2
2009-10-21, 00:03
No problem, I love this skin. But prefer the dvd option on the main menu, which is doable.
2009-10-21, 09:09
Your code works in the vertical menu, but not the horizontal.
Also I think there is a confilict with the video menu label.
I changed <item id="1"> to <item id="17"> and moved it to the end of the menu list.
now for the horizontal menu
2009-10-21, 19:43
Sorry, that's cause I just set it up for the vertical menu.
2009-10-21, 22:07
I updated the file to support the horizontal menu and one small bug fix. Turns out when you change the id numbers it messes up the little info box that can appear on the bottom right. It's all fixed now.
2009-10-22, 03:13
Cheers Michael, simple copy and paste but nice to finish things of
2009-10-22, 10:11
never realized so many people found this feature useful...
guess i'll have to add it to my todo list. ;-)
2009-10-22, 11:17
ronie Wrote:never realized so many people found this feature useful...
At first I wasn't interested since I enabled DVD autoplay in XBMC settings but following the thread it has started to look as a nice addition.
I specially like the fact that this option only shows up in the menu if a DVD (DVD-Video?) is inserted so not to confuse/take up space otherwise.
I imagine that there are useful scenarios for this feature and if present in a new T! release I may disable the autoplay since I notice that when XBMC starts it tries to display any DVD in the drive even if it's a data disc. (That brings up a really zoomed in icon
+1 for having this option
2009-10-22, 11:26
i thought the 'play disk' button in the player controls (the ones you can bring up by pressing 'm' or 'menu' when a disc is inserted) was good enough for everyone.....but i guess i was wrong. :-)
2009-10-22, 13:17
Quote: i thought the 'play disk' button in the player controls (the ones you can bring up by pressing 'm' or 'menu' when a disc is inserted) was good enough for everyone.....but i guess i was wrong. :-)
So Play DVD on the main menu perhaps add no missing feature but it's more of a "candy sugar" WAF thing.
Just to throw a quick couple of examples:
- I bound my remote to a button that displays the audio/subs menu while watching a movie so I can change them easily. Wrong, yesterday I spent half a minute trying to understand how should I go to select the audio option, then the tiny up/down arrows and then a new audio track. I'm sure it's easy but I don't even know the sequence I pulled up and probably will have to go through this exercise a couple of more times.
- I discovered that when you are moving through a list (ex: artists) if you keep pressing right eventually the cursor locks on the vertical scroll bar so from them on the up/down arrows moves the bar (faster scroll than going row to row). A feature I wasn't even aware of.
So really XBMC exposes so many options than sometimes the skinner may choose to "highlight" some of the most important giving them prime space on the main menu.
PS: I cannot wait to see how many cool things the new T! will bring.
2009-10-22, 15:15
Thanks for this, very useful. Gonna give it a go on my xbox.
2009-10-22, 15:33
yadster Wrote:Thanks for this, very useful. Gonna give it a go on my xbox.
Tried it and it works perfectly on xbox using the horizontal menu. Thanks.
2009-10-22, 17:57
adsoto Wrote:I think that quite a few of us (me being the first) don't even know half of the options available in the zillion of menus / popups windows / context menus present on XBMC.
That was the issue with me, until I saw this thread I was unaware of the m menu on the home page.
Pages: 1 2
