From my /UserData/sources.xml
<source>
<name>queeup Video Feeds</name>
<path pathversion="1">rss://ankara.baskent.edu.tr/~obaskin/rss/video.xml/</path>
</source>
<source>
<name>deadelvis Video Feeds</name>
<path pathversion="1">rss://www.specialdefects.com/xbmc/video.xml</path>
</source>
Xbox consistently throws a "Could not connect to network server" error with the second feed... while it works just fine with the first.
I can't for the life of me figure out why this is so, specially since both feeds are just basically the same.
Any help would be MUCH appreciated.
Please read stickies on how to post in a useful manner.
In particular, the full debug log on pastebin please.
Sorry tslayer... my bad.
Platform: Xbox. Built on Jun 26 2009 (SVN:21142, compiler 1310)
skin:[Project Mayhem III]
Full debug log:
http://pastebin.com/m6c186eb4
Please upgrade, if possible, to a version after 21769. There was a recent change to rss source handling.
Please upgrade and report back.
Platform: Xbox. Built on Aug 4 2009 (SVN:21991, compiler 1310)
Skin: Project Mayhem III v2.11
Full debug log:
http://pastebin.com/m6557500e
Previous was latest T3ch... this one from sshcs.com/xbmc
Error seems to be exactly the same
14:18:05 M: 25944064 INFO: Initializing feed: http://www.specialdefects.com/xbmc/video.xml
14:18:05 M: 25944064 DEBUG: FileCurl::Open(D00A0458) http://www.specialdefects.com/xbmc/video.xml
14:18:05 M: 25907200 INFO: XCURL::DllLibCurlGlobal::easy_aquire - Created session to http://www.specialdefects.com
14:18:05 M: 25804800 DEBUG: kernel32.dll fake function GetFullPathNameA called
14:18:06 M: 25804800 DEBUG: FileCurl::Close(D00A0458) http://www.specialdefects.com/xbmc/video.xml
14:18:06 M: 25907200 ERROR: DIRECTORY::CDirectory::GetDirectory - Error getting rss://www.specialdefects.com/xbmc/video.xml/
14:18:06 M: 25907200 ERROR: CGUIMediaWindow::GetDirectory(rss://www.specialdefects.com/xbmc/video.xml/) failed
I have r22072 and can confirm it is still a problem.
mpadilla2
not merged to xbox probably
To clarify, I am on windows xp and receiving the error.
Most rss feeds I attempt to add are useless as most receive the error reported by the original poster.
I cannot seem to locate r21293 anywhere. I've looked at zipped, kricker, ikons, and jester builds and cannot locate r21293.
Can someone point me in the direction of r21293?
Provide your debug log then.
I used the same rss feeds as the original poster. I am now on build r22103. Debug log at
http://pastebin.com/m1228be6f
Although I used the original posters rss feeds I get the same error with my other feeds.
Please read the stickies. We specifically want a FULL DEBUG LOG. Do not CUT it.
rss file is borken. it needs rss:// in the links, not http://
else if(strcmp(item_child->Value(), "link") == 0) {
if (item_child->GetText()) {
string strLink = item_child->GetText();
string strPrefix = strLink.substr(0, strLink.find_first_of(":"));
if (strPrefix == "rss") {
// If this is an rss item, we treat it as another level in the directory
item->m_bIsFolder = true;
item->m_strPath = strLink;
else if (item->m_strPath == "" && IsPathToMedia(strLink)) {
