Full Version: How to launch python scripts?
can any tell me or give me a link to a tutorial that will help with what to do with all the python scripts i have download. i know that u have to edit one of your .xml files from xbmc, but i dont know which one and how to. what exactly do i do to launch the scripts from python.
"when i installed xbmc new build from irc, the python and script file was there too, but no scripts or files in both of the folders"
the scripts (*.py files) should be in the "xbmc\scripts" folder. you can run them within xbmc. somewhere in a setting menu you find "scripts" when you select this you see all the scripts in the folder. by selecting a script and press "a" you run it.
succes,
atmoz
