Full Version: default sleep instead shutdown
i have only two bubbles in blue bubbles in "power off menu"
quit XBMC
sleep
but when i jump to power off menu, the defult choice is shut down but i don't have shut down there Smile
is there any way how to set sleep as default?
Magua Wrote:Hi,
quit XBMC
sleep
just put the shutdown button back in the shutdown menu.
next go to Settings > System > Hardware > Shutdown function > Suspend.
this should get you the desired behavior.
great, easy, i'll try it, thanks
