Full Version: Transfer from PC to XBMC Live
Is there anyway i can transfer files to by XMBC LIVE PC.
Like to the way you can PC to PC, using the network share folders or mapping a network drive.
I would like to be able to transfer files from my main pc to my XMBC Live PC.
Hi and welcome to the forum.
Download winscp, install then run on your windows pc. Type in your xbmclive ip adress then use "xbmc" (without the quotes) as the username and password. If you installed xbmc-live to a hard drive use the password you chose during the xbmc-live installation. When you connect you will be in your xbmc-live home directory. From there you can just drag and drop files. You can also use samba, its faster but is more complicated to set-up.
cheers.
