I have a TV show, its a documentary from the history channel. Since it is only one episode it doesnt follow the "SxxExx protocol. How can I get this to play from my TV Show list? It doesnt even show in library mode.
You can make an nfo file it with the info you want. Then refresh it and I believe it will enter into the db (library).
Here is a sample one to get you started if you want it.
http://pastebin.com/d773fc7ad
Obviously you will need to change all the fields by hand.
The thing it, MediaInfoPlus finds info on it and makes an nfo. I just cant get it to show in the library.
just call it s01e01, you may have to enter it on thetvdb as well if its not already listed.
I tried to use the Tv show format but still it wont show.
then you need to add it to thetvdb
