Full Version: [SMB]Trying to access network share
Hi all
Lets say upfront i dont own a xbox myself, i have a x360.
My neighbour has a xbox, and he wants to use this as a media center.
This xbox is already modded, and ofcourse it has xbmc (dont know what version, should be an old one).
This xbox connects to MY local lan, wich has a server(10.10.10.1) serving 2tb data on the lan via smb/http/afp.
All clients on the network can access the share ( also a pc at my neighbours house, so i can rule out a config issue on my side.)
Now, when i want to connect via smb in xbmc, i go to setting and enter the relevant info there under smb.....
(smb://10.10.10.1/media)
10.10.10.1
share name : media
password: paswexample.
Every time i go to Movies --> Smb Share , i will get a popu asking me for the username and pasw of "dont know the name" samba server ( wich isnt mine ofc), i also verified there is no other samba share running on the network.
If i enter the credentials again it will pop back up asking me for the credentials of
smb://DOMAINsmb://10.10.10.1
How can i resolve this issue?
Sadly i dont know the version numbers right now, cause im at work atm.
I would think a upgrade/update of xbmc would be the way to go, however, i cannot seem to connect to the FTP of the xbox either(yes it was enabled).
I do know the xbmc/xbox is connected to internet etc, since i see the rss feed, and can check the weather on the xbox.
Lets say i would be able to get into the ftp of the xbox, how would i install the latest version?
I have the following directory schematic of the downloaded xbmc....
[root@gateway XBMC]# ls -lha
total 7.9M
drwxr-xr-x 14 root root 4.0K May 15 13:29 .
drwxr-xr-x  3 root root 4.0K May 15 13:26 ..
-rw-r--r--  1 root root  26K Apr 28 21:55 copying.txt
drwxr-xr-x  2 root root 4.0K May 15 13:26 credits
-rw-r--r--  1 root root 7.8M May  9 10:48 default.xbe
-rw-r--r--  1 root root 4.8K Apr 28 21:55 keymapping.txt
drwxr-xr-x  5 root root 4.0K May 15 13:27 language
drwxr-xr-x  3 root root 4.0K Aug  9 22:57 media
drwxr-xr-x  4 root root 4.0K May 15 13:27 plugins
drwxr-xr-x  7 root root 4.0K May 15 13:27 screensavers
drwxr-xr-x 16 root root 4.0K May 15 13:27 scripts
drwxr-xr-x  5 root root 4.0K May 15 13:28 skin
drwxr-xr-x  3 root root 4.0K May 15 13:29 sounds
drwxr-xr-x  7 root root 4.0K May 15 13:29 system
drwxr-xr-x  4 root root 4.0K May 15 13:29 UserData
drwxr-xr-x  8 root root 4.0K May 15 13:29 visualisations
drwxr-xr-x  4 root root 4.0K May 15 13:29 web
