Full Version: [RELEASE] Video Fanart Splitter Script - Movie and TV Show FanArt Seperation
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14
Ohh yeah... running Win7 x64
XBMC is completely std. installation
Skin is Transparency
Hello ronie,
Have you had time to test your script with Aeon MQ 3 Dharma?
I'm using your v2.0.5 with no issues, but not able to get it working with this modded for Dharma version skin.
anauticax Wrote:Ohh yeah... running Win7 x64
from the home menu choose 'programs' then 'program addons'.
the script is listed there and you can run it from that location.
if there's no 'programs' entry in your home menu, you need to add it:
skin settings > menu.
shadetree Wrote:Have you had time to test your script with Aeon MQ 3 Dharma?
nope, should i? :-)
shadetree Wrote:I'm using your v2.0.5 with no issues, but not able to get it working with this modded for Dharma version skin.
video fanart splitter is as standalone script (ie you can run it from program add-ons).
whatever the skin does with this script is outside of my reach,
i think you'd better ask for help in the aeon thread.
ronie Wrote:video fanart splitter is as standalone script (ie you can run it from program add-ons).
Yes, now thinking...lol...the splitter created the directories and writing content correctly to them so I will need to be more patient and wait for a reply form the 110958 forum.
ronie Wrote:hmm...looks like that's the 'symlink' version of the script someone posted a while ago.
as far as i know that one will only work on linux.
you may have better luck with this one:
script.video-fanart-splitter-v2.0.5.zip
hey peeps i installed this script but get a script error whenever i try to run the config...
and when i scroll to movies the background is blank..
xbmc 10.1
skin aeon mq3
