Full Version: [RELEASE] Video Fanart Splitter Script - Movie and TV Show FanArt Seperation
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14
Could someone help me with getting the Video Fanart Splitter up and running? I added the latest 0.2.5 version, enabled HTTP access but I still get an error. Here's the log:
21:13:16 T:7216 M:1439862784 NOTICE: -->Python Interpreter Initialized<--
21:13:16 T:7216 M:1439952896 ERROR: Error Type: exceptions.IndexError
21:13:16 T:7216 M:1439952896 ERROR: Error Contents: list index out of range
21:13:16 T:7216 M:1439940608 ERROR: Traceback (most recent call last):
File "C:\Users\Andi\AppData\Roaming\XBMC\addons\script.video-fanart-splitter\default.py", line 77, in ?
each = getCrc(cur_raw.split("</field><field>")[0][7:] + cur_raw.split("</field><field>")[1][:-8])
IndexError: list index out of range
check if you get any search results when clicking this link,
you may need to adjust the port number if xbmc is not configured at port 8080 on your pc.
http://127.0.0.1:8080/xbmcCmds/xbmcHttp?...movieview)
Thanks, this solved it. I did use port 80 before which was fine with the remote app on my iPad, but fanart splitter doesn't seem to like it (no search results). After setting it to 8080 both run fine now.
@Ronie:
Is there any chance the Fanart Splitter ends up in an XBMC repository?
I really like the script... but nowadays grabbing a Zip-file is 'strange', knowing that all other add-ons are so easily obtainable Wink
FYI:
Version 0.2.5 works well on XBMC (Live) 10.1!
ronie Wrote:i've made some modifications to the script and it should work fine on nightlies
Corvo Wrote:@Ronie:
to be honest, it's up to skaymakca to decide if he wants to submit it,
it's his script after all. :-)
and since he didn't add a license file to the script, i don't even have a clue if it's ok to modify and redistribute the script as i did... let alone me submitting it to the repo.
Thanks for the info, Ronie.
In that case, I sure hope skaymakca decides to add it to a repo.
i need some help getting the tv show fanart to work
im using the aeon mq2 skin
im not getting any tv show fanart in my userdata/addon-data folder
maseatx Wrote:i need some help getting the tv show fanart to work
are you using v2.5 of the script?
check if the webserver is enabled in xbmc and if the portnumber matches the portnumber in the addon settings.
yes it wroks fine with movies but nothing is in the tv shows folder
ok so i copied a .tbn file from movies and placed it in the tv folder that is in addon_data and that file shows up on the tvshow home screen.
so could it be
aConfusedplitter not splitting
bConfusedomething with the scrapper
cConfusedomething wrong with the folder structure
p.s. structure is currently as follows
Tvshows
...........show
.................show season 1
......................show 1x1
......................show 1x2
......................show 1x3
.................show season 2
......................show 2x1
......................show 2x2
......................show 2x3
maseatx Wrote:yes it wroks fine with movies but nothing is in the tv shows folder
have you scanned your tvshows to the library?
yes via add content
do you get any results if you click this link when xbmc is running:
http://127.0.0.1:80/xbmcCmds/xbmcHttp?co...path%29%29
you may have to change the portnumber in the url,
depending on how you configured the webserver in xbmc.
C:\Users\Home\Desktop\Xbmc\TV Shows\Chappelles Show\C:\Users\Home\Desktop\Xbmc\TV Shows\Entourage\
ok and is this correct?
do you have exactly 2 tv shows in your library?
and if you browse your tv show library, does it show the fanart images there?
