2009-08-11, 16:18
2009-08-11, 18:54
tikkiew Wrote:I got mine xbox games and retro games separated .I wonder if you can make 2
game menu buttons?
sure you can. just look in Home.xml for the code of the current Games button.
duplicate the code, give it a new id (one that isn't already used) and make it point to your seconds games folder.
or just modify one of the other buttons, if there's one you don't use.
that would probably the easiest way.
2009-08-11, 21:26
I know how to do this.I mean if you can put this in settings > home screen options.
So there would be 2 option in home menu: xbox games and classic games/old games/retrogames or emulators.
But I think I will move all my games in 1 directory.
To bad xbmc doesn't recognize shortcuts that would be much easier I think I will request this.
2009-08-11, 22:25
tikkiew Wrote:I know how to do this.I mean if you can put this in settings > home screen options.
yep, there will be an emulators menubutton in the next version ;-)
2009-08-12, 03:26
ronie Wrote:yep, there will be an emulators menubutton in the next version ;-)
sweet
