Full Version: library update fails for Music Videos
Hi guys,
XBMC rev21857
WinXP Pro SP3
Transparency! 1.0 skin
I've currently got a Home Video Library, set as Music Videos so I can add them to the XBMC library. After adding the source, setting content to Music Videos, and scanning initially, everything works great...but when adding new files to the source directory, nothing is added to the XBMC library with the startup scan. My movies and tvshow libraries are updated fine during the initial XBMC startup scan, but not the Music Videos. Manually right clicking the Home Videos source and choosing 'scan for new content' doesn't update the library either. a log shows this for the manual update attempt:
21:44:25 T:3500 M:1703403520   DEBUG: VIDEO::CVideoInfoScanner::Process - Starting scan
21:44:25 T:2584 M:1703383040   DEBUG: thread start, auto delete: 0
21:44:25 T:2584 M:1703378944   DEBUG: Thread 2584 terminating
21:44:25 T:3500 M:1703378944   DEBUG: VIDEO::CVideoInfoScanner::DoScan Scanning dir 'Z:\Home Videos\' as not in the database
21:44:25 T:3500 M:1703370752   DEBUG: Hash[musicvideos,Z:\Home Videos\]:DB=[],Computed=[F9E967155F6C0FB1AC61CF04549461FB]
21:44:25 T:3500 M:1703354368   DEBUG: Not adding item to library as no info was found :(
21:44:25 T:3500 M:1703354368   DEBUG: VIDEO::CVideoInfoScanner::DoScan - Finished dir: Z:\Home Videos\
21:44:25 T:3500 M:1703337984   DEBUG: VIDEO::CVideoInfoScanner::DoScan Skipping dir 'Z:\Home Videos\2008\' due to no change
21:44:25 T:3500 M:1703333888   DEBUG: Hash[musicvideos,Z:\Home Videos\2008\]:DB=[DA426B4E14C28BC28CE469D4F0EDF374],Computed=[DA426B4E14C28BC28CE469D4F0EDF374]
21:44:25 T:3500 M:1703321600   DEBUG: VIDEO::CVideoInfoScanner::DoScan - Finished dir: Z:\Home Videos\2008\
21:44:25 T:3500 M:1702862848   DEBUG: VIDEO::CVideoInfoScanner::DoScan Skipping dir 'Z:\Home Videos\2009\' due to no change
21:44:25 T:3500 M:1702834176   DEBUG: Hash[musicvideos,Z:\Home Videos\2009\]:DB=[AF95036C9ADAE29B15608BFA8CAE4525],Computed=[AF95036C9ADAE29B15608BFA8CAE4525]
21:44:25 T:3500 M:1702838272   DEBUG: VIDEO::CVideoInfoScanner::DoScan - Finished dir: Z:\Home Videos\2009\
21:44:25 T:3500 M:1702891520   DEBUG: VIDEO::CVideoInfoScanner::Process - Finished scan
21:44:25 T:3500 M:1702887424  NOTICE: My Videos: Scanning for video info using worker thread, operation took 00:00
21:44:25 T:3500 M:1702858752    INFO: Video scan was stopped or finished ... restoring FindRemoteThumbs
21:44:25 T:3500 M:1703436288   DEBUG: Thread 3500 terminating
Any ideas? At this point, every single time I have a new video, I had to remove the source and re-add it, since only the initial scan works.
any ideas?
