Full Version: RTSP Streaming from Live555 or Darwin Streaming Server
Hi Guys, first post.
I have setup the latest XBMC on an Apple TV.
I have tried streaming rtsp from both live555 and Darwin Streaming server using mov, mp4 and mpeg2ts files.
I created a strm file and placed it in the frontrow home directory, it contained a url rtsp://vvx3:8554/bridgestone.ts to a host running live555 that works fine from VLC.
I get the following error in my log file.
08:49:19 T:2684407808 M: 36642816 NOTICE: DVDPlayer: Opening: rtsp://vvx3:8554/bridgestone.ts
08:49:19 T:2684407808 M: 36651008 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
08:49:19 T:51884544 M: 36659200 NOTICE: Creating InputStream
08:49:19 T:51884544 M: 36634624 NOTICE: Creating Demuxer
08:49:19 T:51884544 M: 36564992 ERROR: OpenDemuxStream - Error creating demuxer
08:49:19 T:51884544 M: 36564992 NOTICE: CDVDPlayer::OnExit()
08:49:19 T:51884544 M: 36564992 NOTICE: CDVDPlayer::OnExit() deleting input stream
08:49:19 T:2684407808 M: 36564992 ERROR: Playlist Player: skipping unplayable item: 0, path [rtsp://vvx3:8554/bridgestone.ts]
08:49:19 T:2684407808 M: 36556800 NOTICE: CDVDPlayer::CloseFile()
08:49:19 T:2684407808 M: 36556800 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
08:49:19 T:2684407808 M: 36556800 NOTICE: DVDPlayer: waiting for threads to exit
08:49:19 T:2684407808 M: 36605952 NOTICE: DVDPlayer: finished waiting
Any help much appreciated.
If other people have this working can they suggest what I'm doing wrong or an alternative solution.
Thanks,
Damian.
Sorry guys just noticed the post requirements
Additional information supplied:
Darwin appletv1.btisystems.co.uk.local 8.8.2 Darwin Kernel Version 8.8.2: Mon Jan 29 18:57:29 PST 2007; root:xnu-792.94.18~1/RELEASE_I386 i386 i386
XBMC 9.04.1
Launcher 3.1
Stream: bridgestone.ts
Type: MPEG transport stream
Duration: 0:00:30
Data Size: 48.24 MB
Bit Rate: 13.34 Mbps
Video Tracks:
4096 MPEG-2, 720 × 576, 16:9, 25 fps, 20.00 Mbps, progressive
Audio Tracks:
4098 MP2 stereo, 48 kHz, 384 kbps
Stream Files:
bridgestone.ts (48.24 MB)
Hi guys if noone has experience of the above, any info on using xbmc/appletv to stream rtsp from a VOD server would be much appreciated.
Thanks,
Damian.
damianoneill Wrote:Bit Rate: 13.34 Mbps
I think this video is too much for atv... you should try 3.00 Mbps.
Hi Guys,
If anyone has experience , any info on using xbmc to stream rtsp or mms from a VOD server would be much appreciated.
Is it possible to install it on a tiny linux client (Amount of memory needed ?)
Is it possiblle to install it on a dedicated server ?
Thanks,
Damian.
I'm also having this problem.
Have you fixed it?
Does DVDPlayer support rtsp?
Or is there a way to install mplayer?
