rflores2323: the bios image surely dont work. but if you search for MMTool on google, you will end up with several guides for customizing bios. Note though, that if you screw up.. the machine is most likely toast without a massive rescue operation. It will also void any warranties.
athloni Wrote:Can you explain me how to patch the BIOS for the Asrock ION 330HT (new)?
Especialy the "dell" thing
The info about the "dell" thing is in mydigitallife.info forums.
Rion Wrote:Can you make these for the Asrock ION 330 Pro/HT/BD version?
The latest version now is 1.10
I prefer not to as I do not have Asrock ION 330 Pro/HT.
I always test them before posting because of the risk of many people brick their precious IONs because of me...
Anyone can config videos using nVIDIA Compute Unified Device Architecture (CUDA) with XBMC internal player ?
My hardware ASRock ION330HT !!!1
I put up a request for these modded bioses on
http://bios-mods.com.
For Asrock ION 330 Pro/HT/BD Bios version 1.10
Did not even take a day before they where finished!
Link to thread
http://bios-mods.com/forum/showthread.php?tid=1427
Rion Wrote:Asrock ION 330 Pro/HT/BD
Hi! Stumbled upon this web page true XBMC.org forums.
Anyway i would like to request a custom bios Image for my Asrock ION 330 Pro/HT/BD.
Latest version of the bios is 1.10 and can be found here:
http://www.asrock.com/nettop/download.as...0Pro&o=All
Mr grubia on XBMC have made these for the Asrock ION 330 revision but he will not and don't want to take responsibility for any modification done on an Pro/HT/BD version since he don't have one.
The link to the thread is here.
http://forum.xbmc.org/showthread.php?tid=56324
So all in all i would like to have these bios images (pictures) posted above for the new version of Asrock's Netop Series Pro/HT/BD (Same bios for all versions)
Thank you so much
Best Regards
/Rion
1234s282 Wrote:RE: Asrock ION 330 Pro/HT/BD
Here you are , ive modded it 3 times , including each custom boot screen you linked to each time
Flash at your own risk!
http://dl.dropbox.com/u/747181/Asrock%20...34s282.zip
Regards
Admin
You can request Custom Logo/Splash Screen yourself on the forums.
Edit: I have tested them all and they work
Hi grubia,
thx for the advice using IrfanView. The first time I screwed my BIOS.
The second time I saved the image using IrfanView and my BIOS is up and running!
My Zotac IONITX-A now it looks like this:
/Edit
This BIOS is only for
ZOTAC IONITX - A / B / C / D ! BIOS Version 2K090813 (25.09.2009)
http://www.mediafire.com/download.php?59tk59mnngkerb4
woah damn, that's sleek
gotta request something like this for my netbox
BurningSky Wrote:Hi grubia,
thx for the advice using IrfanView. The first time I screwed my BIOS. The second time I saved the image using IrfanView and my BIOS is up and running!
I'd love to have that logo for my Bios, can you post on here or PM what steps I need to get my Zotac Ionitx-L-E bios looking like that?
-=Jason=-
You have PM.
/Edit
Uploaded my custom BIOS in my other post.
Hi everyone,
does anyone know if a custom BIOS for ASRock ION330HT based on bios v1.20 exists?
Kind regards
Larry_Lobster
ah well, I completely forgot about this thread. as the new foxconn BIOS (P06) fixes the fan noise and I probably won't need to do another update, could somebody be so kind as to integrate an XBMC logo into this binary? with silent boot enabled I only see a small text line so it should be possible to integrate a custom splash image.
http://www.megaupload.com/?d=NX6501T3
p.s. it's an AMI BIOS file
