Full Version: PDA's compatible with Xbmc
hi, after searching the forums, i didn't come across clear info on which pda/pocket pc's work with xbmc. Are all the wifi PDA's compatible with xbmc or are they some that do not work?? also, is there some versions of windows that you cannot install the apps on to??
cheers
If your phone got wi-fi and a browser the application from XiniX88 will work.!!
Your phone only needs to open a url.
