2009-08-14, 21:28
hi,
I just configured my new POV ION 330 Setup.
Everything is working fine and stable. Last litte problem is the remote.
I got this one:
Running ubuntu 9.04 minimal and xbmc svn r22133
Followed this guide: http://wiki.xbmc.org/?title=XBMCbuntu
Installed lirc with apt-get install lirc and choosed "Windows Media Center Remotes new version"
Tested with irw and it works.
The problem is it is far away from beeing smooth.
(As for example the original remote from an xbox1). Or the remote of an dvb-2 card working with lirc on another Computer.
Scrolling down and up in xbmc for example is like 10times slower as doing it with an keyboard plugged in.
Here are my lirc settings:
hardware.conf
lircd.conf
lircd.conf.mceusb
I played around with "gap", but it got even worse that way.
root@xbmc:~# dmesg|grep lirc
root@xbmc:~# lsusb
Second problem is that lirc_dev is running by default even is lirc itself is not installed. That leeds to an "Starting LirC [failed]" at every boot.
And after returning from suspend mode somethimes there is a lirc_dev error message insted of returning to xbmc. So is there any way to disable lirc_dev?
Anyone has this remote and has it running smoothly with xbmc?
Any suggestions? Help?
thanks!
I got this one:
hardware.conf
# /etc/lirc/hardware.conf
#Chosen Remote Control
REMOTE="Windows Media Center Remotes (new version Philips et al.)"
REMOTE_MODULES="lirc_dev lirc_mceusb2"
REMOTE_DRIVER=""
REMOTE_DEVICE="/dev/lirc0"
REMOTE_LIRCD_CONF="mceusb/lircd.conf.mceusb"
REMOTE_LIRCD_ARGS=""
#Chosen IR Transmitter
TRANSMITTER="None"
TRANSMITTER_MODULES=""
TRANSMITTER_DRIVER=""
TRANSMITTER_DEVICE=""
TRANSMITTER_LIRCD_CONF=""
TRANSMITTER_LIRCD_ARGS=""
#Enable lircd
START_LIRCD="true"
#Don't start lircmd even if there seems to be a good config file
#START_LIRCMD="false"
#Try to load appropriate kernel modules
LOAD_MODULES="true"
# Default configuration files for your hardware if any
LIRCMD_CONF=""
#Forcing noninteractive reconfiguration
#If lirc is to be reconfigured by an external application
#that doesn't have a debconf frontend available, the noninteractive
#frontend can be invoked and set to parse REMOTE and TRANSMITTER
#It will then populate all other variables without any user input
#If you would like to configure lirc via standard methods, be sure
#to leave this set to "false"
FORCE_NONINTERACTIVE_RECONFIGURATION="false"
START_LIRCMD=""
lircd.conf
#Configuration for the Windows Media Center Remotes (new version Philips et al.) remote:
include "/usr/share/lirc/remotes/mceusb/lircd.conf.mceusb"
lircd.conf.mceusb
begin remote
name mceusb
bits 16
flags RC6|CONST_LENGTH
eps 30
aeps 100
header 2667 889
one 444 444
zero 444 444
pre_data_bits 21
pre_data 0x37FF0
gap 105000
toggle_bit 22
rc6_mask 0x100000000
begin codes
[ 8.417791] lirc_dev: IR Remote Control driver registered, major 61
[ 8.536984] lirc_dev: lirc_register_plugin: sample_rate: 80
[ 9.153141] usbcore: registered new interface driver lirc_mceusb
[ 9.153279] lirc_mceusb: USB Microsoft IR Transceiver Driver v0.2
[ 16.480141] lirc_mceusb2: Philips eHome USB IR Transceiver and Microsoft MCE 2005 Remote Control driver for LIRC $Revision: 1.44 $
[ 16.480147] lirc_mceusb2: Daniel Melander <[email protected]>, Martin Blatter <[email protected]>
[ 16.483423] usbcore: registered new interface driver lirc_mceusb2
root@xbmc:~# lsusb
Bus 004 Device 003: ID 045e:006d Microsoft Corp. eHome Remote Control Keyboard keys
thanks!
