Where can I read more about creating a text box with different opacity.
Like discussed in this topic
http://forum.xbmc.org/showthread.php?tid=49956
I guess this is a stupid/simple question, but I can't find anything at the forum...
Just change the font colour to add a bit of transparency to it.
Or use a conditional fade animation to do the same.
No... I don't get it...
If I just want to create a square with some amount of opacity.
Is there anything like drawbox(xcoordinate, ycoordinate, size, opacity), no?
as far as I know you need to use a physical texture from the media folder. the only ways to change the appearance image is to blend with another image using <texture diffuse or with a fade animation. at its simplest something like this
<control type="image">
<posx>130</posx>
<posy>43</posy>
<width>720</width>
<height>500</height>
<texture>backpanelplist.png</texture>
<visible>Control.HasFocus(50)</visible>
<animation effect="fade" start="0" end="20" time="200" condition="Control.HasFocus(50)">Conditional</animation>
</control>
I have yet to really get my head around it yet but it seem to me that most of the time you need to use photo shop to make/modify your textures to suite your needs and I really hate using Adobe software
Father Parsley Wrote:No... I don't get it...
add a <colordiffuse>foo</colordiffuse> to the image control.
if i understand you corectly, you want something like this:
[HTML]
<posx>400</posx>
<posy>200</posy>
<width>500</width>
<texture>square.png</texture>
<colordiffuse>88FFFFFF</colordiffuse>
</control>[/HTML]
Thanks! <colordiffuse>88FFFFFF</colordiffuse> did the trick!
Next question... nothing with opacity this time, but I post it in the same thread anyway...
The movie thumbnail icons comes in different sizes when downloaded from, say IMDb.
But I want all the thumbnail icons fill up the same space on the screen
[HTML]<control type="image">
<width>174</width>
<height>250</height>
</control>[/HTML]
If one thumbnail icons has a different ratio, it will not fill up the whole space.
How to do?
Father Parsley Wrote:Thanks! <colordiffuse>88FFFFFF</colordiffuse> did the trick!
<width>174</width>
</control>[/HTML]
How to do?
there's an excellent skinning manual available for xbmc.
it has the answer to this, your previous and most likely your next question ;-)
http://wiki.xbmc.org/?title=Image_Control
ah yes, found it [HTML]<aspectratio>scale</aspectratio>[/HTML]
thanks guys!
ronie Wrote:it has the answer to this, your previous and most likely your next question ;-)
hehe yes will try read more closely before next question
no...
<aspectratio>keep</aspectratio>
in the online manual it says
Quote:When set to “scale” then the box will be resized so that it completely fills the <width>,<height> box and any portions of the image outside the box will be cropped off.
NO! it should be "scale".
but
<posx>0</posx>
<posy>300</posy>
<width>178</width>
<height>256</height>
<info>ListItem.Icon</info>
</control>
gives me a square image. why?!??
