I got an old eMac that has a 1Ghz PowerPc with 512mb of RAM so I figure it could run xbmc. I downloaded it and tried to install but it was a no go. The icon has a crossed out symbol over the xbmc symbol and when I double click it says something along the lines of "This application is not supported". Any ideas. The OS is OS X 10.+
Any ideas ?
Ry J Wrote:I got an old eMac that has a 1Ghz PowerPc with 512mb of RAM so I figure it could run xbmc. I downloaded it and tried to install but it was a no go. The icon has a crossed out symbol over the xbmc symbol and when I double click it says something along the lines of "This application is not supported". Any ideas. The OS is OS X 10.+
Any ideas ?
Need 10.4 min. Also make sure you download the PPC version and not the Intel version.
davilla Wrote:Need 10.4 min. Also make sure you download the PPC version and not the Intel version.
That certainly explains the two different versions for download. I tried the ppc one and it works. Thank you.
But I am unable to full screen. Is that possible with the mac version ?
