2009-08-23, 01:36
Solved, see below.
Hello,
I'm setting up a new box with xbmc and have ran into the following issue using the main release repository:
The only google result for this error suggest the multiverse isn't enabled. I've unchecked and rechecked the multiverse tick box and can see the file coming down when I do an update:
So it suggests my aptitude install may be borked? Anyone have any ideas how to troubleshoot this further?
Hello,
sudo apt-get install xbmc
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies.
xbmc: Depends: xbmc-common (= 9.04.1-jaunty1) but it is not going to be installed
Depends: xbmc-skin-pm3-hd (= 9.04.1-jaunty1) but it is not going to be installed
Depends: xbmc-web-pm3 (= 9.04.1-jaunty1) but it is not going to be installed
E: Broken packages
sudo apt-get update
Hit http://nz2.archive.ubuntu.com jaunty Release.gpg
Hit http://nz2.archive.ubuntu.com jaunty/main Translation-en_GB
Hit http://nz2.archive.ubuntu.com jaunty/universe Translation-en_GB
Hit http://nz2.archive.ubuntu.com jaunty/restricted Translation-en_GB
Hit http://nz2.archive.ubuntu.com jaunty/multiverse Translation-en_GB
