Full Version: Search Url not shown
Pages: 1 2
Ok I understood you that it isn't possible now when you mentioned that i got it working.
Was a problem in my scraper.
Right now I have the scraper in /usr/share/... because .xbmc/system/scrapers/video didnt work.
Do they only work out of the /usr path?
Oh and i found out that german äöü arent working with the search because xbmc converts them.
yes only in /usr and use SearchStringEncoding to set the search string encoding (duh). also make sure your scraper xml is set to the correct encoding.
Got it working a thing that can't be done with the editor yet.
But no problem inserting it manualy.
Pages: 1 2
