2009-08-28, 12:28
2009-08-28, 13:18
taxigps Wrote:When I use weather.com plus, values of temperature at the bottom not display
it sometimes takes a short while before the values appear.
you can also bring out the left menu and hit 'refresh', maybe this will help.
2009-08-28, 15:24
Hi Ronie,
AppleTV
xbmc r22240
1.)In skin settings > backgrounds if you are on the"Animated Backgrounds" and go up on a remote control it actually takes you down. I would have thought that it would take me to the bottom of the list.
Not sure if you meant for it to be like that or not.
2.) in system info, when you enter it it shows "Basic Information" , if you scroll down/up it doesn't change until you click the selected tab. Maybe it should change as you scroll. just my $0.02
Zeljko
AppleTV
xbmc r22240
Zeljko
2009-08-28, 15:38
ronie Wrote:it sometimes takes a short while before the values appear.
Your right, it works!
But some font are too big in chinese. I suggest to add font tag like this in Includes_Weather.xml
<control type="label">
<posx>140</posx>
<posy>223</posy>
<width>140</width>
<height>20</height>
<font>font-20</font>
<align>right</align>
<textcolor>lightblue</textcolor>
<label>$LOCALIZE[402][CR]$LOCALIZE[406][CR]$LOCALIZE[403][CR]$LOCALIZE[405][CR]$LOCALIZE[404]</label>
</control>
<posx>160</posx>
<posy>223</posy>
<width>250</width>
<height>20</height>
<label>$INFO[Window(Weather).Property(Current.FeelsLike)]$INFO[System.TemperatureUnits][CR]$INFO[Window(Weather).Property(Current.Humidity)][CR]$INFO[Window(Weather).Property(Current.UVIndex)][CR]$INFO[Window(Weather).Property(Current.DewPoint)]$INFO[System.TemperatureUnits][CR]$INFO[Window(Weather).Property(Current.Wind)]</label>
</control>
2009-08-28, 16:13
taxigps Wrote:Your right, it works!
thanx! looks like i forgot to add a font-size to those controls.
cheers.
2009-08-28, 16:49
Yeah I noticed at first it took a while for my first weather temps to appear.
2009-08-28, 18:04
Amet Wrote:1.)In skin settings > backgrounds if you are on the"Animated Backgrounds" and go up on a remote control it actually takes you down. I would have thought that it would take me to the bottom of the list.
the 'animate backgrounds' is a button control. below that is a list control.
you can't specify a certain item in the list to get focus.
actually it remembers the last focused item in the list and it will take you back there on up and down.
Amet Wrote:2.) in system info, when you enter it it shows "Basic Information" , if you scroll down/up it doesn't change until you click the selected tab. Maybe it should change as you scroll.
this is handled by xbmc and i agree, they should change the behaviour.
nothing i can do about it.
2009-08-28, 18:14
ronie Wrote:that's strange...all you have to do is enable the button (skin settings > scripts > show subtiltle script button in osd)
and then the osd menu should look like this:
not sure why it doesn't work for you.
I am such an idiot sometimes, in order to compare fonctionalities of v1.03 and the beta, I had both 1.03 and the beta in the skins folder and I had remamed it Transparency!beta. Everything worked fine except for clearart and the subtitles. Obviously certain features call for the skin name to be Transparency!. Once I removed 1.03 and renamed the beta, everything works as it should.
So people, don't do like me or you'll be wasting a lot of your time and ronie's for nothing
2009-08-28, 18:26
ronie Wrote:the 'animate backgrounds' is a button control. below that is a list control.
Cheers mate.
2009-08-28, 22:10
im not sure if this is a bug.
more than likely i just did something screwy when i set things up and i havent figured out how to fix it yet.
basically the only issue i have had with this beta is that in the main tv shows menu i have only the default fan art.
it wont load my fan art for my shows until i select a show and enter the seasons menu.
at which point everything else appears fine.
example of the screen im referring to
like i said tho it may not be a bug more likely im just a moron.
i did however make sure that in the settings/backgrounds list tv shows is set to default so im not sure where else the backgounds for the tv shows list page can be changed.
2009-08-28, 22:37
Vampirebat Wrote:im not sure if this is a bug.
Yep, and confirmed by Ronie. Hang tight... ;-)
2009-08-28, 22:55
Same here for Movies and Tv Shows.
2009-08-28, 23:47
kizer Wrote:Same here for Movies and Tv Shows.
my movies fanart works fine its just tv shows for me.
2009-08-31, 12:31
Ronie, is there going to be another Beta please? Testing T! without most of the 'know' issues would let people (at least me) have a renewed focus T! with the bug-eye.
Thx
Thx
2009-08-31, 13:40
pooh Wrote:Ronie, is there going to be another Beta please?
nope, but there will be a final in a few days ;-)
