i see the XBMC Hardware system requirements
http://wiki.xbmc.org/?title=Supported_hardware
the info say XBMC requirements Graphic Card Supports OpenGL1.4 +GLSL or later。
I try to ATI RADEon8500le and intel CeleronD2.53Ghz based computer running XBMC, can work.
however, in another of my Nforce2 IGP Graphic Card With AthonXP computer can not run the XBMC. The nForce2IGP M7NCG400 old motherboard with S-video TV-out, I can connect using the old TV.
ATI RADEON8500LE supports DX8.1 and OpenGL 1.3 100% (with OpenGL1.4 86%,everest say),nForce2 IGP Built-in graphics core supports DX7 and DX8 All 26 properties in 24, be equal to Geforce4 MX420 ,
Someone can tell me what way to be able to run XBMC do to achieve NForce2IGP ?
I do not know if clearly stated, because my standard of English was less than,Thank you all!
vs2vs2 Wrote:however, in another of my Nforce2 IGP Graphic Card With AthonXP computer can not run the XBMC.
Elaborate. Also, see the stickied post about reporting problems in a useful manner.
thank you!
i get the debug log files report:
23:00:36 T:1984 M:192286720 NOTICE: -----------------------------------------------------------------------
23:00:36 T:1984 M:192270336 NOTICE: Starting XBMC, Platform: Windows XP Professional Service Pack 3 build 2600. Built on Aug 5 2009 (SVN:22017, compiler 1500)
23:00:36 T:1984 M:192270336 NOTICE: AMD Athlon
23:00:36 T:1984 M:192270336 NOTICE: Desktop Resolution: 1024x768 32Bit at 60Hz
23:00:36 T:1984 M:192270336 NOTICE: Running with administrator rights
23:00:36 T:1984 M:192270336 NOTICE: special://xbmc/ is mapped to: C:\XBMC
23:00:36 T:1984 M:192270336 NOTICE: special://masterprofile/ is mapped to: C:\Documents and Settings\Administrator\Application Data\XBMC\userdata
23:00:36 T:1984 M:192266240 NOTICE: special://home/ is mapped to: C:\Documents and Settings\Administrator\Application Data\XBMC
23:00:36 T:1984 M:192266240 NOTICE: special://temp/ is mapped to: C:\Documents and Settings\Administrator\Application Data\XBMC\cache
23:00:36 T:1984 M:192266240 NOTICE: The executable running is: C:\XBMC\XBMC.exe
23:00:36 T:1984 M:192266240 NOTICE: Log File is located: C:\Documents and Settings\Administrator\Application Data\XBMC\xbmc.log
23:00:36 T:1984 M:192266240 NOTICE: -----------------------------------------------------------------------
23:00:36 T:1984 M:191639552 NOTICE: Setup SDL
23:00:39 T:1984 M:191369216 NOTICE: load settings...
23:00:39 T:1984 M:191344640 NOTICE: special://profile/ is mapped to: special://masterprofile/
23:00:39 T:1984 M:191344640 NOTICE: loading special://masterprofile/guisettings.xml
23:00:39 T:1984 M:190500864 NOTICE: Getting hardware information now...
23:00:39 T:1984 M:190492672 NOTICE: Checking resolution 10
23:00:39 T:1984 M:190492672 NOTICE: Setting autoresolution mode 3
23:00:39 T:1984 M:190410752 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
23:00:39 T:1984 M:190373888 NOTICE: Loaded playercorefactory configuration
23:00:39 T:1984 M:190361600 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
23:00:39 T:1984 M:190361600 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
23:00:39 T:1984 M:190357504 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
23:00:39 T:1984 M:190357504 NOTICE: Default DVD Player: dvdplayer
23:00:39 T:1984 M:190357504 NOTICE: Default Video Player: dvdplayer
23:00:39 T:1984 M:190357504 NOTICE: Default Audio Player: paplayer
23:00:39 T:1984 M:190685184 NOTICE: special://masterprofile/sources.xml
23:00:41 T:1984 M:186212352 NOTICE: GL_VENDOR = NVIDIA Corporation
23:00:41 T:1984 M:186212352 NOTICE: GL_RENDERER = GeForce4 MX Integrated GPU/AGP/SSE/3DNOW!
23:00:41 T:1984 M:186212352 NOTICE: GL_VERSION = 1.5.7
23:00:41 T:1984 M:186212352 NOTICE: GL_EXTENSIONS = GL_ARB_imaging GL_ARB_multitexture GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_texture_rectangle GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_paletted_texture GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shared_texture_palette GL_EXT_stencil_wrap GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_vertex_array GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_fence GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_packed_depth_stencil GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_register_combiners GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_NV_texture_rectangle GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_SGIS_generate_mipmap GL_SGIS_multitexture GL_SGIS_texture_lod GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
23:00:43 T:1984 M:188674048 NOTICE: initializing playlistplayer
23:00:43 T:1984 M:188674048 NOTICE: DONE initializing playlistplayer
23:00:43 T:1984 M:188600320 NOTICE: load default skin:[PM3.HD]
23:00:44 T:1984 M:183422976 NOTICE: initialize done
23:00:44 T:1984 M:183422976 NOTICE: Running the application...
23:00:44 T:1984 M:183390208 NOTICE: ES: Starting event server
23:00:44 T:1060 M:183361536 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
23:00:44 T:1060 M:183361536 NOTICE: UDP: Listening on port 9777
23:01:33 T:1984 M:176189440 ERROR: convert_checked failed
23:16:36 T:1984 M:168255488 NOTICE: Storing total System Uptime
23:16:36 T:1984 M:168255488 NOTICE: Saving settings
23:16:36 T:1984 M:168038400 NOTICE: stop all
23:16:36 T:1984 M:168038400 NOTICE: ES: Stopping event server
23:16:37 T:1060 M:168095744 NOTICE: ES: UDP Event server stopped
23:16:37 T:1984 M:168022016 NOTICE: stop sap announcement listener
23:16:37 T:1984 M:168083456 NOTICE: clean cached files!
23:16:37 T:1984 M:168079360 NOTICE: unload skin
23:16:37 T:1984 M:184918016 NOTICE: stop python
23:16:37 T:1984 M:184918016 NOTICE: stopped
23:16:37 T:1984 M:184918016 NOTICE: destroy
23:16:37 T:1984 M:184872960 NOTICE: unload sections
------------------end-----
Above athlonXP system uses SAGEM 760A 54mbps wifi adapter to access the network。
OS:windows XP sp3,AthlonXP CPU@ 1.75GHz
RAM:512MB
GPU:GeForce4 MX Integrated ,Drivers:93.71
The emergence of a black window during operation stopped
thank all!
i retry setup windowsXP OS, now XBMC is WROK!!
Added:
I guess I have found the problem is that it is Nvidia for the GeForce4 MX Integrated graphics provided by the official final result of 93.71 WHQL drivers. This driver provides a OpenGL2.0 support, see URL:
http://www.nvidia.com/object/winxp_2k_93.71_2.html
Rev 71.89 drivers are provided purely driven by the fans, only the necessary files.
Can I use an old version of the driver rev71.89 running XBMC, but it fails to run after the update to Rev93.71. I wish that it should be able to run XBMC on the old mainframe guys be useful.
I also tried another earlier WHQL Rev91.47 driven, results and Rev93.71 the same token, can not let XBMC work.
Unfortunately, giving up WHQL Rev93.71 lost NVIDIA PureVideo™ HD driver features:
Hardware acceleration of H.264, VC-1 and MPEG-2 HD movie formats.
Video post-processing image enhancements.
