2009-08-24, 23:02
2009-08-24, 23:02
2009-08-24, 23:28
Place at line 780 and at line 820 in your ViewsVideo.xml...
2009-08-24, 23:45
PiNCH strikes again! Thanks buddy, as you can tell im newish to xbmc and the skinning community, actually I just found out about mediastream a few days ago, appreciate your help.
2009-08-25, 00:57
hmmm, that didn't seem to work for me. I edited with crimson viewer text editor because I couldn't see the line numbers in notepad and it didn't have much effect, other than the media preview view mode and showcase view mode mimicked the look of info list view but without the movie information on the side. In panel stream view mode it looked the same as before.
I made a mistake before by saying I was looking to remove the move title bar and dvd title bar in panel stream view. As in the picture shown above, I meant the media preview view mode. My mistake
2009-08-25, 01:18
pinkybreak Wrote:I made a mistake before by saying I was looking to remove the move title bar and dvd title bar in panel stream view. As in the picture shown above, I meant the media preview view mode. My mistakeI got that
<control type="group">
<visible>Skin.HasSetting(HideInfoInMediaPreview) + !Skin.HasSetting(ShowAnimMediaPreview)</visible>
<control type="image">
<width>1280</width>
<height>54</height>
<texture>Black.png</texture>
<colordiffuse>99cccccc</colordiffuse>
</control>
<posy>450</posy>
<width>1280</width>
<height>64</height>
</control>
<description>Glass overlay for movie title to sit on</description>
<posx>343</posx>
<width>593</width>
<height>50</height>
<texture>GlassTitleBar.png</texture>
</control>
<control type="label">
<description>Title</description>
<posy>8</posy>
<width>1280</width>
<align>center</align>
<label>$INFO[ListItem.Label]</label>
<font>TitleCapsFont</font>
<scroll>true</scroll>
</control>
</control>
</control>
This is the control you want to disable. Should start at about line 780 (I've already added the "<!-- -->").
... or you can go for the really easy way: add an exclamation mark to the second line,
<visible>[b]![/b]Skin.HasSetting(HideInfoInMediaPreview) + !Skin.HasSetting(ShowAnimMediaPreview)</visible>
I'm trying to learn all of this myself, so if I get the time tomorrow I'll see if I can figure out how to enable/disable the panel through the interface.
2009-08-25, 01:41
