Full Version: Radmin & xbmc
Hello,
Has anyone managed to use XBMC from another remote PC using RADMIN software?
There seems to be always a stuck when using RADMIN and XBMC is open.
My folks has HTPC and it runs radmin server. I can use everything from remote pc in case they need any help with HTPC. But when they have XBMC running, it starts normally but then the remote pc doesnt update the screen / is stuck.
(Radmin is working remote ok with all the other programs* - even tv with dvbviewer
*Solidworks and other openGL softwares shows only black plain screen)
so you're saying that all opengl software fails to work. no wonder xbmc fails then....
