2009-08-26, 06:16
I have problem playing DTS wav file in XBMC. I enabled digital out and DTS/DD passthrough. If I play DTS wav file, it only plays two channel and not 5.1. Surprisingly, if I play AVI with 5.1 AC3 sound, it plays perfectly fine.
Below is the log file. The first file played is DTS wav file and second playback is AVI (which works fine).
Since AVI works fine, I think there seems to be no problem with the hardware setup. I also tried playing DTS wav file using AC3filter (spdif passthrough) and it played fine. Hence there is something I am missing in XBMC.
Any help will be highly appreciated.
Logs : http://pastebin.com/m422954e3
