Full Version: Playing a file from a network share
I'm having a problem playing a video from a file on a SMB share.
I'm running XBMC on Ubuntu Jaunty, and reading a list of files from a MySQL database.
I create a list of buttons with the name of each file. When a button is clicked, tthe dialog is shown, and when OK is clicked, XBMC hangs and has to be killed with a kill -9.
Heres the script that I'm working with:
import xbmc, xbmcgui
import MySQLdb
import re
conn = MySQLdb.connect (host = '192.168.0.200',
            user = 'root',
            passwd = '',
            db = 'mynewmovies')
#get actioncodes from keymap.xml
ACTION_PREVIOUS_MENU = 10
class MyClass(xbmcgui.Window):
  def __init__(self):
    self.strActionInfo = xbmcgui.ControlLabel(250, 80, 200, 200, '', 'font14', '0xFFBBBBFF')
    self.addControl(self.strActionInfo)
    self.strActionInfo.setLabel('Push BACK to quit')
    self.list = xbmcgui.ControlList(200, 150, 600, 600)
    self.addControl(self.list)
    cursor = conn.cursor(MySQLdb.cursors.DictCursor)
    cursor.execute("select title, url from movie inner join moviexlinks on movie.id = moviexlinks.movieid where linktype = 'movie' order by if(titlesort = '', title, titlesort)")
    results = cursor.fetchall()
    for row in results:
    self.list.addItem(row["url"])
    self.setFocus(self.list)
  def onAction(self, action):
    if action == ACTION_PREVIOUS_MENU:
      self.close()
  def onControl(self, control):
    if control == self.list:
      item = self.list.getSelectedItem()
      r = re.compile('\\\\')
      file = "smb:" + r.sub('/', item.getLabel())
      self.message('You selected : ' + file)
      xbmc.Player().play(file)
  def message(self, message):
    dialog = xbmcgui.Dialog()
    dialog.ok(" My message title", message)
mydisplay = MyClass()
mydisplay.doModal()
del mydisplay
Here's xbmc.log
19:01:42 T:2764523856 M:1518145536   DEBUG: Load DialogOK.xml: 34.98ms
19:01:42 T:3174295616 M:1518145536   DEBUG: ------------------- GUI_MSG_WINDOW_INIT
19:01:42 T:3174295616 M:1518145536   DEBUG: Dialog OK
19:01:42 T:3174295616 M:1518145536   DEBUG: Load button-focus2.png: 0.3ms (bundled)
19:01:42 T:3174295616 M:1518145536   DEBUG: Load button-nofocus.png: 0.2ms (bundled)
19:01:42 T:3174295616 M:1518145536   DEBUG: Alloc resources: 1.26ms (0.03 ms skin load, 0.21 ms preload)
19:01:42 T:3174295616 M:1518145536   DEBUG: Load DialogBack.png: 13.7ms (bundled)
19:01:42 T:3174295616 M:1517154304   DEBUG: Load DialogFront.png: 28.8ms (bundled)
19:01:42 T:3174295616 M:1516118016   DEBUG: Load separator.png: 0.2ms (bundled)
19:01:44 T:3174295616 M:1515757568   DEBUG: SDLKeyboard: scancode: 36, sym: 13, unicode: 13, modifier: 0
19:01:44 T:3174295616 M:1515757568   DEBUG: OnKey: 61453 pressed, action is 7
19:01:45 T:3174295616 M:1516085248   DEBUG: ------------------- GUI_MSG_WINDOW_DEINIT
19:01:45 T:3174295616 M:1516085248   DEBUG: Dialog OK
19:01:45 T:3174295616 M:1515978752   DEBUG: new file set audiostream:0
19:01:46 T:3174295616 M:1516019712   DEBUG: CPlayerCoreFactory::GetPlayers(smb://tardis/video/Doctor Who/01 William Hartnell/Series 01/001 An Unearthly Child/00 - Pilot Episode - An Unearthly Child .avi)
19:01:46 T:3174295616 M:1516019712  NOTICE: DVDPlayer: Opening: smb://tardis/video/Doctor Who/01 William Hartnell/Series 01/001 An Unearthly Child/00 - Pilot Episode - An Unearthly Child .avi
19:01:46 T:2663094608 M:1515974656   DEBUG: Running thread 2663094608
19:01:46 T:2663094608 M:1515974656   DEBUG: thread start, auto delete: 1
19:01:46 T:3174295616 M:1515974656 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
19:01:46 T:2654701904 M:1515839488   DEBUG: Running thread 2654701904
19:01:46 T:2654701904 M:1515839488   DEBUG: thread start, auto delete: 0
19:01:46 T:2654701904 M:1515839488  NOTICE: Creating InputStream
19:01:46 T:2654701904 M:1515839488   DEBUG: OpenDir - Using authentication url smb://tardis/video
19:01:49 T:2663094608 M:1515708416    INFO: Loading skin file: DialogProgress.xml
19:01:49 T:2663094608 M:1515708416   DEBUG: Load DialogProgress.xml: 17.57ms
19:01:49 T:2663094608 M:1515708416   DEBUG: DialogProgress::StartModal called
19:01:49 T:2663094608 M:1515708416   DEBUG: ------------------- GUI_MSG_WINDOW_INIT
19:01:49 T:2663094608 M:1515708416   DEBUG: Progress dialog
19:01:49 T:2663094608 M:1515708416   DEBUG: Load button-focus2.png: 0.2ms (bundled)
19:01:49 T:2663094608 M:1515708416   DEBUG: Load button-nofocus.png: 0.1ms (bundled)
19:01:49 T:2663094608 M:1515708416   DEBUG: Alloc resources: 0.94ms (0.03 ms skin load, 0.14 ms preload)
I figure that it's probably something simple, but I'm new to this.
Brian
I figured out what the problem was.
The path stored in the database was in windows format: \\server\share\path_to_file
The script changed the path to: smb"//server/share/path_to_file
The problem turned out to be authentication. I need to look into this some more because the share is open for read access to all users.
The fix was to change the path to: smb://user:password@server/share/path_to_file
Anyone have an idea as to why authentication is required?
Brian
I don't know exactly, had some similar issues with my subtitle plugins, it may be that the authentication is not be shared between XBMC itself and the Python engine?!
