Full Version: Windowed mode on movie play
Hi, I'm having a strange problem that I haven't seen described before, but would certainly like to fix.
The problem is thus:
Whenever I play a movie from my hard drive from the movie view, xbmc will go to a semi-windowed state. In this state the taskbar will appear and the xbmc task will blink orange as if to indicate it has a new task or has completed something.
Oddly, this only occurs under the movie view, TV shows and playing from the file manager present no problems. I am running Aeon Showmix 1.70 but this problem occurs under all skins I've tested.
It's probably noteworthy that the problem stopped upon an update a few days ago, but resumed when I updated a few days later. I don't remember the build numbers sorry, but if you need anything else please let me know.
I would truly appreciate help!
Edit: Nevermind, someone in the windows help section posted slightly before me and I didn't see it, I apologize.
Regardless, I fixed the issue by turning on the "Disable desktop composition" after right-clicking the xbmc.exe.
