Full Version: Can't bring up menu for a TV show spread over multiple folders
Before I post a bug report I'm hoping someone could confirm this problem I'm having:
I noticed I can't bring up the menu (by pressing 'i') for one of the TV shows in my library. This might be a total coincident, but the only thing I can spot that's different about this particular show is that the episodes are spread out over two folders.
J:\TV\Pushing Daisies\
K:\TV\Pushing Daisies\
Can someone please confirm that this is indeed the reason for the menu not working?
debug log of you trying to bring up the info for that entry would probably be the easiest way to confirm the cause.
Oops, should have mentioned that there was nothing going on in the debug log
04:47:14 T:3700 M:544706560   DEBUG: SDLKeyboard: scancode: 23, sym: 105, unicode: 105, modifier: 1000
04:47:14 T:3700 M:544706560   DEBUG: CApplication::OnKey: 61513 pressed, action is 11
04:47:16 T:3700 M:546734080   DEBUG: SDLKeyboard: scancode: 56, sym: 308, unicode: 0, modifier: 1000
I'm using the Windows version of build 22516
it might be better to post a full debug log just in case you've missed something
I'm not at that computer right now, but there was nothing else. There were no errors or warnings and I waited a minute before pressing 'i' to make it clear in the timestamps where the keypress took place.
