2009-09-03, 19:21
Hello.
I´m running XBMC 9.04.1 over Mythbuntu 9.04 on an AMD 64. I got the PC preconfigured, but I guess that XBMC was installed from the repositories (PPA).
The problem I´ve noticed is that when I play any video in XBMC, it mutes the Master audio control. I have the output audio set as "hdmi" so that the sound goes to the TV. While I´m playing anything in XBMC, there is not problem on hearing it on the TV, but when I shutdown XBMC I realize that the Master audio is muted and I have to unmute it manually if I want to hear anything on other outputs (such as SPDIF, for example).
I have two sample debugs:
http://pastebin.ubuntu.com/264537/plain/
It just shows the start and shutdown of XBMC not playing any video. Before and after of it the Master audio was unmuted.
http://pastebin.ubuntu.com/264542/plain/
I start XBMC, play a video (about 18:49 hour) and close XBMC. Afterwards, I check alsamixer and see that the Master control is muted.
As long as I listen to the videos on the TV there is not problem; but if I want to change the audio output to anything else (like "iec958") I have to previously unmute the Master control on alsamixer.
I would appreciate any help.
I hope I have posted enough information, but I can post anything else that may help.
Thank you very much.
