Full Version: X Error on Fedora 11 when I control xbmc via a remote web-browser
Hi,every one
There is something wrong with XBMC on Fedora 11 about web-server function.
I enable web-server in XBMC ,then go to another pc,play media files in server by firefox.Everything seems fine, then I view my pictures ,but when I change another picture file,XBMC crashed.
It won't occur when playing video files.I try to compile the same source on Fedora 10,It alsa doesn't happen.
I also test on Moblin, when I use older version(20090616 with Mesa 7.4 ),everything's fine.But the currrent version (20090818 with mesa 7.5) alsa has the same problem.
Is it mesa's problem?(But other 3D application works fine like neverball(a game using SDL and opengl)
Anyone knows that?
Here is some message of this issue:
Environment: Fedora 11
3D Driver: Mesa 7.6
XBMC_version: XBMC-pre-9.10(SVN Sep 01)
X error message:
X Error of failed request: BadAccess (attempt to access private resource denied)
Major opcode of failed request: 152 (GLX)
Minor opcode of failed request: 26 (X_GLXMakeContextCurrent)
Serial number of failed request: 79645
Current serial number in output stream: 79645
CRITSEC[0x8bf7564]: Trying to enter destroyed section.
CRITSEC[0x8bf75f0]: Trying to enter destroyed section.
XBMC log:
08:13:24 T:3085871040 M:251977728 DEBUG: ------ Window Deinit (Home.xml) ------
08:13:24 T:3085871040 M:251977728 DEBUG: ------ Window Init (SlideShow.xml) ------
08:13:24 T:3085871040 M:251977728 INFO: Loading skin file: SlideShow.xml
08:13:24 T:3085871040 M:251977728 DEBUG: Load SlideShow.xml: 2.44ms
08:13:24 T:3085871040 M:251977728 DEBUG: Alloc resources: 2.82ms (2.80 ms skin load)
08:13:24 T:2558397296 M:251977728 DEBUG: Running thread 2558397296
08:13:24 T:2558397296 M:251977728 DEBUG: thread start, auto delete: 0
08:13:24 T:3085871040 M:251977728 DEBUG: Loading the current image /root/Desktop/opt/SampleMedia/Pictures/spring-rolls.jpg
08:13:24 T:2558397296 M:249040896 DEBUG: Finished background loading /root/Desktop/opt/SampleMedia/Pictures/spring-rolls.jpg
08:13:24 T:2558397296 M:247635968 DEBUG: Duration: 570 (transistion out length 124)
08:13:24 T:3085871040 M:251822080 DEBUG: SECTION:LoadDLL(special://xbmc/system/libexif-i486-linux.so)
08:13:24 T:3085871040 M:251822080 DEBUG: Loading: /usr/local/share/xbmc/system/libexif-i486-linux.so
08:13:26 T:2838481776 M:251850752 DEBUG: webs: accept request
08:13:26 T:3085871040 M:251850752 DEBUG: Loading the current image /root/Desktop/opt/SampleMedia/Pictures/Honey.png
08:13:26 T:2558397296 M:250302464 DEBUG: Finished background loading /root/Desktop/opt/SampleMedia/Pictures/Honey.png
08:13:26 T:2558397296 M:250302464 DEBUG: GL: Sharing screen surface for thread 2558397296
08:13:27 T:2558397296 M:250368000 ERROR: (pthread_mutex_destroy(&m_mutex)): [XCriticalSection.cpp:83] 16
08:13:27 T:2558397296 M:250884096 WARNING: Cleanup: Having to cleanup texture pointer-nofocus.png
08:13:27 T:2558397296 M:250884096 DEBUG: GL: Sharing screen surface for thread 2558397296
Eek
It's called patience. When someone comes along who knows they'll answer you.
"......" Is not acceptable.
And a proper report would help. Please read stickies on how to post a problem in a useful manner.
Do you have intel graphics there seems to be a problem with them with the new UXA drivers.
see this post on Boxee forums: http://forum.boxee.tv/showthread.php?t=8487
