Full Version: a little help for the OSD
I some one can help me a little bit.
I have just started using this media center, but im having som problems with this skin. I can't find where to set up audio and subs wen I'm seing the movie, in the mediastream skin I can press "m" and then a navigation menu comes up. but if I press "m" in this skin I can't se any thing else then the progress bar.
I hope some one can help me with this?
I also have another small problem. i cant set up the backdrups. i have found the menu, and i can select a file or folder, but nothing happens.
I also hope you can helpe with this.
Press 'Enter' and get a newer XBMC build.
Hitcher Wrote:Press 'Enter' and get a newer XBMC build.
if i press "enter" i just get the bookmarksetting create an delete bookmark
where can i find a newer build?
