I'm working on adding the whole watched/unwatched stuff to the Xperience and just noticed that the overlay is still visible on videos played already.
Currently our code is as such:
<control type="image">
<posx>656</posx>
<posy>100</posy>
<width>70</width>
<height>70</height>
<info>ListItem.Overlay</info>
<visible>!IsEmpty(ListItem.Overlay)</visible>
<texture>views\list\Other\new.png</texture>
</control>
This is in the movies library if anyone is curious, oh and
doesnt seem to show anything.
Any help would be great!
ListItem.Overlay is the image.
Thus, it'll either be Watched.png or Unwatched.png or whatever they are. It won't be empty.
Cheers,
Jonathan
jmarshall Wrote:ListItem.Overlay is the image.
Cheers,
Jonathan
OK great, keeping in mind I'm not much for coding
<visible>!$INFO(ListItem.Overlay)</visible>
Doesn't seem to like me either ....
OK this was a bit more simpler than i thought.
I moved the texture to the main media folder renamed it to OverlayUnWatched.png and used the following code:
<texture>$INFO
[ListItem.Overlay]</texture>
All is well now.
Why not just make the OverlayWatched.png or whatever it is the image you want?
That's what listitem.overlay returns, so no need for vis conditions.
EDIT: I see you figured that out for yourself
Thanks anyways Jonathan!
Cheers.
Sorry to resurrect such an old thread but I was wondering: what should we do if we wanted to have two separate watched / unwatched overlay images? One for text lists and one for poster lists. It'd be really great to have something like ListItem.IsWatched to accommodate this.
Edit: Sorry again, figured out a workaround using the following code:
<description>Overlay</description>
<posx>380</posx>
<posy>6</posy>
<width>23</width>
<height>23</height>
<texture>overlaywatched-list.png</texture>
<visible>Substring(ListItem.Overlay,Watched.png) + !Substring(ListItem.Overlay,Unwatched.png)</visible>
</control>
Sranshaft Wrote:Sorry to resurrect such an old thread but I was wondering: what should we do if we wanted to have two separate watched / unwatched overlay images? One for text lists and one for poster lists. It'd be really great to have something like ListItem.IsWatched to accommodate this.
<posx>380</posx>
<posy>6</posy>
<width>23</width>
<height>23</height>
</control>
This is where you use two different Unwatched.png and Watched.png and the second couple of packs in a subfolder.
use UnWatched.png and Watched.png in the List folder:
<posx>380</posx>
<posy>6</posy>
<width>23</width>
<height>23</height>
<texture>[b][color=black]List/[/color][/b]$INFO
</control>
use UnWatched.png and Watched.png in the Panel folder:
<posx>380</posx>
<posy>6</posy>
<width>23</width>
<height>23</height>
<texture>[b]Panel/[/b]$INFO
</control>
This should work.
