Full Version: [Request] Can someone (Stanley87?) help fix ResumeX?
After updating XBMC on my Xbox from an old build (2.10) to the latest stable build according to T3CH (9.04.1) i discovered ResumeX no longer works! Shocked
This script makes XBMC on Xbox the perfect media centre for my car, so without it i am struggling.
I had a look at fixing it up myself... Put the data.xml and settings.xml from Scripts\ResumeX\lib into the UserData\Script_data\RexumeX folder (no more write permission to the scripts folder?), and then changed the code to use the new special:// paths but then Xbmc crashes on restarting. I'm afraid its above my skills, and i hope someone can help make it work
(I guess Stanley87 is no longer working on it?)
Since someone might ask where i got to and what the logs are, here is the default.py
http://pastebin.com/m1103326b
And the lib\engine.py
http://pastebin.com/m74b934a6
And one of the XBMC log files, i believe this resulted in a black screen on the Xbox:
http://pastebin.com/m73ba1ae0
