2009-09-10, 21:32
I'm running 9.4 Repack 2 on WinXP64.
I've just bought The Office Season 5, and I've ripped it to a set of 5 .iso files (one for each disc), as I've done with each of the other TV show DVDs I've got. In the past, I've had no problems with this, but for some reason it now only wants to add the final episode on each .iso to the library.
If I use either the "Update Library"* function, or I go out of library mode, find the TV show folder and use "TV Show Information" to add it to the library, it seems to show every episode being downloaded properly from TheTVdb.com -- I see episode numbers and names properly reporting in the box -- but when I look at the actual episode listing, only the first n discs (where n is a number between 0 and 4) actually had their episodes added properly, the remainder only getting the last episode.
The files are structured like so:
I've tried the various settings that look like they might have an effect ("stack duplicate TV shows", "Treat stacked files as single file"), but nothing seems to help.
Does anyone know what I can do to make this work properly? Thanks in advance.
*As an aside, I used to use the "automatic update" function to scan for new movies / shows when I started XBMC, but a while back that stopped picking anything up, and I switched to doing it manually. In the course of my investigations today, I've discovered that every single sub-folder in my libraries is set to "exclude path from library updates", which isn't what I want. Is there any way to stop it setting this flag on new folders created (by the OS) within an existing source? Or to unset it globally without having to go through several hundred folders manually?
J:\TV Shows\The Office (US)\The Office.5x01.5x02.5x03.5x04.5x05.iso
J:\TV Shows\The Office (US)\The Office.5x06.5x07.5x08.5x09.5x10.5x11.iso
J:\TV Shows\The Office (US)\The Office.5x12.5x13.5x14.5x15.5x16.iso
J:\TV Shows\The Office (US)\The Office.5x17.5x18.5x19.5x20.5x21.5x22.iso
J:\TV Shows\The Office (US)\The Office.5x23.5x24.5x25.5x26
