flxfxp Wrote:Are you using a keyboard? Try it with that. If it doesnt work, try the newbie section.
edit: i've sorted that now i was trying to go in via the video tab
i'm still not getting audio though.
i've set the video output to analog and everything is set to hdmi, hdmi is enabled in the bios.
i've tried different hdmi cables and hdmi ports on my amp and still nothing.
i'm getting an error message when i try and playback video or music saying "failed to initialize audio device check device settings"
could this be as i've installed the latest build? i'm thinking as i'm a noob i should i reinstall everything and stick with the stable build, what do you think?
i
flxfxp Wrote:Did you reboot? check to make sure the keys are coming through correctly. kill the bluetooth deamon by doing "sudo killall bluetoothd" and start it manually with debug by doing "sudo bluetoothd -nd"
Let me know of the results.
Yes i did, i followed your tutorial step-by-step!
here is the result.
When i press any key on the ps3 remote, there are no new entries in the debug log.
PHP Code:
xbmc@ubuntu:~$ sudo killall bluetoothd
xbmc@ubuntu:~$ sudo bluetoothd -nd
bluetoothd[3000]: Bluetooth daemon 4.54
bluetoothd[3000]: Enabling debug information
bluetoothd[3000]: parsing main.conf
bluetoothd[3000]: discovto=0
bluetoothd[3000]: pairto=0
bluetoothd[3000]: pageto=8192
bluetoothd[3000]: name=%h-%d
bluetoothd[3000]: class=0x000100
bluetoothd[3000]: discov_interval=0
bluetoothd[3000]: Key file does not have key 'DeviceID'
bluetoothd[3000]: Starting SDP server
bluetoothd[3000]: Loading builtin plugins
bluetoothd[3000]: Loading audio plugin
bluetoothd[3000]: Loading input plugin
bluetoothd[3000]: Loading serial plugin
bluetoothd[3000]: Loading network plugin
bluetoothd[3000]: Loading service plugin
bluetoothd[3000]: Loading hciops plugin
bluetoothd[3000]: Loading hal plugin
bluetoothd[3000]: Loading storage plugin
bluetoothd[3000]: Loading plugins /usr/local/lib/bluetooth/plugins
bluetoothd[3000]: register_interface: path /org/bluez/3000/any
bluetoothd[3000]: Registered interface org.bluez.Service on path /org/bluez/3000/any
bluetoothd[3000]: Parsing /etc/bluetooth/network.conf failed: No such file or directory
bluetoothd[3000]: Config options: InterfacePrefix=bnep%d, PANU_Script=(null), GN_Script=(null), NAP_Script=(null), GN_Interface=pan0, NAP_Interface=pan1, Security=true
bluetoothd[3000]: bridge pan0 created
bluetoothd[3000]: Parsing /etc/bluetooth/input.conf failed: No such file or directory
bluetoothd[3000]: Parsing /etc/bluetooth/audio.conf failed: No such file or directory
bluetoothd[3000]: Unix socket created: 9
bluetoothd[3000]: Telephony plugin initialized
bluetoothd[3000]: HFP AG features: "Ability to reject a call" "Enhanced call status" "Extended Error Result Codes"
bluetoothd[3000]: HCI dev 0 registered
bluetoothd[3000]: child 3002 forked
bluetoothd[3000]: btd_adapter_ref(0xb8b76970): ref=1
bluetoothd[3000]: Failed to open RFKILL control device
bluetoothd[3000]: Entering main loop
bluetoothd[3000]: HCI dev 0 up
bluetoothd[3000]: Starting security manager 0
bluetoothd[3000]: Changing Major/Minor class to 0x000104
bluetoothd[3000]: register_interface: path /org/bluez/3000/hci0
bluetoothd[3000]: Registered interface org.bluez.Service on path /org/bluez/3000/hci0
bluetoothd[3000]: network_server_probe: path /org/bluez/3000/hci0
bluetoothd[3000]: btd_adapter_ref(0xb8b76970): ref=2
bluetoothd[3000]: Adding record with handle 0x10000
bluetoothd[3000]: Record pattern UUID 0000000f-0000-1000-8000-00805f9
bluetoothd[3000]: Record pattern UUID 00000100-0000-1000-8000-00805f9
bluetoothd[3000]: Record pattern UUID 00001002-0000-1000-8000-00805f9
bluetoothd[3000]: Record pattern UUID 00001115-0000-1000-8000-00805f9
bluetoothd[3000]: register_server_record: got record id 0x10000
bluetoothd[3000]: Registered interface org.bluez.NetworkPeer on path /org/bluez/3000/hci0
bluetoothd[3000]: Adding record with handle 0x10001
bluetoothd[3000]: Record pattern UUID 00001117-0000-1000-8000-00805f9
bluetoothd[3000]: register_server_record: got record id 0x10001
bluetoothd[3000]: Registered interface org.bluez.NetworkHub on path /org/bluez/3000/hci0
bluetoothd[3000]: Adding record with handle 0x10002
bluetoothd[3000]: Record pattern UUID 00001116-0000-1000-8000-00805f9
bluetoothd[3000]: register_server_record: got record id 0x10002
bluetoothd[3000]: Registered interface org.bluez.NetworkRouter on path /org/bluez/3000/hci0
bluetoothd[3000]: proxy_probe: path /org/bluez/3000/hci0
bluetoothd[3000]: btd_adapter_ref(0xb8b76970): ref=3
bluetoothd[3000]: Registered interface org.bluez.SerialProxyManager on path /org/bluez/3000/hci0
bluetoothd[3000]: Parsing /etc/bluetooth/serial.conf failed: No such file or directory
bluetoothd[3000]: btd_adapter_ref(0xb8b76970): ref=4
bluetoothd[3000]: headset_server_probe: path /org/bluez/3000/hci0
bluetoothd[3000]: btd_adapter_ref(0xb8b76970): ref=5
bluetoothd[3000]: audio_adapter_ref(0xb8b77f88): ref=1
bluetoothd[3000]: Adding record with handle 0x10003
bluetoothd[3000]: Record pattern UUID 00000003-0000-1000-8000-00805f9
bluetoothd[3000]: Record pattern UUID 00001108-0000-1000-8000-00805f9
bluetoothd[3000]: Record pattern UUID 00001112-0000-1000-8000-00805f9
bluetoothd[3000]: Record pattern UUID 00001203-0000-1000-8000-00805f9
bluetoothd[3000]: Adding record with handle 0x10004
bluetoothd[3000]: Record pattern UUID 0000111e-0000-1000-8000-00805f9
bluetoothd[3000]: Record pattern UUID 0000111f-0000-1000-8000-00805f9
bluetoothd[3000]: a2dp_server_probe: path /org/bluez/3000/hci0
bluetoothd[3000]: audio_adapter_ref(0xb8b77f88): ref=2
bluetoothd[3000]: SEP 0xb8b79108 registered: type:0 codec:0 seid:1
bluetoothd[3000]: Adding record with handle 0x10005
bluetoothd[3000]: Record pattern UUID 00000019-0000-1000-8000-00805f9
bluetoothd[3000]: Record pattern UUID 0000110a-0000-1000-8000-00805f9
bluetoothd[3000]: Record pattern UUID 0000110d-0000-1000-8000-00805f9
bluetoothd[3000]: avrcp_server_probe: path /org/bluez/3000/hci0
bluetoothd[3000]: audio_adapter_ref(0xb8b77f88): ref=3
bluetoothd[3000]: Adding record with handle 0x10006
bluetoothd[3000]: Record pattern UUID 00000017-0000-1000-8000-00805f9
bluetoothd[3000]: Record pattern UUID 0000110c-0000-1000-8000-00805f9
bluetoothd[3000]: Record pattern UUID 0000110e-0000-1000-8000-00805f9
bluetoothd[3000]: Adding record with handle 0x10007
bluetoothd[3000]: Creating device /org/bluez/3000/hci0/dev_00_19_C1_56_0B_6F
bluetoothd[3000]: btd_device_ref(0xb8b7a1c8): ref=1
bluetoothd[3000]: Probe drivers for /org/bluez/3000/hci0/dev_00_19_C1_56_0B_6F
bluetoothd[3000]: hid_device_probe: path /org/bluez/3000/hci0/dev_00_19_C1_56_0B_6F
bluetoothd[3000]: btd_device_ref(0xb8b7a1c8): ref=2
bluetoothd[3000]: Registered interface org.bluez.Input on path /org/bluez/3000/hci0/dev_00_19_C1_56_0B_6F
bluetoothd[3000]: Adapter /org/bluez/3000/hci0 has been enabled
bluetoothd[3000]: child 3002 exited
bluetoothd[3000]: Computer is classified as desktop
bluetoothd[3000]: Setting 0x000104 for major/minor device class
Hi Dennis i got the sound to work just had to set it up like this -------
Settings -> System -> Audio hardware
Digital = on
Doldy Digital (AC3) capable Receiver = on
DTS Capable Recevier =on
Audio Output Devive = iec958
Passthrough out put device = iec958
Downmixing to stereo = off
so now when i play a Stereo track it plays and my Bose Display show Up PCM
and when i play a film my bose display show up Doldy Digital 5.1 or DTS
Hope this helps some one ok that only leaves one thing left to work how do in
install Appel move plugin and I-player if you can help that would be cool thanks again Dennis
andyblac Wrote:hi flxfxp,
need some help, did the above got to point 10. but XBMC never starts. here my error log, i must mention i am trying to install on a MacPro with 2 HDD's primary HD clean hdd with a master boot record partition map. (created through linux install).
i can get linux full install work with no problems but if i try to run your script it breaks the install. (GUI no longer loads). thats why i tried the above
procedure, it seems to be trying to change the partitions using FDISK ?? but it not compatible with GPT (i assume MAC hd partition scheme)
any ideas ?.
Andy.
Have you tried a normal PC-Keyboard?
Ubuntu has a problem with the Apple-Keyboard-Layout.
Pressing F1 in OS X lower brightness of the display.
Pressing fn+F1 would do the same as pressing F1 on a PC-Keyboard.
Evin Wrote:Even if I wasted an entire Sunday... I solved my problem.
Before running the Script, I installed a desktop:
sudo aptitude -y install xserver-xorg-core xinit menu menu-xdg jwm fluxbox alsa-utils mrxvt gdebi-core synaptic logrotate localepurge
Then, I fixed the issue with the fn-Key on the Mac-Keyboard:
Opened a terminal: sudo nano /etc/modprobe.d/hid_apple.conf
Added this line to the opened file: options hid_apple fnmode=2 and saved it.
Terminal: sudo update-initramfs -u
Then I started your script and installed the stable build. Thanks to the previously fixed keyboardsetting I was able to start the terminal: (right) CTRL + (left) ALT + F2
Tomorrow I will reinstal everything with an normal PC-Kayboard. But I have defeated the ugly Apple-Linux-Dragon on my own. :lol:
Evin Wrote:Have you tried a normal PC-Keyboard?
i think i was down to the fact it was trying to install the NVidia drive that where not compatible with my 7300GT in my MacPro i did a full install from a complete Ubuntu cd and got every working except my PS3 remote. linux is detecting the button press but not XBMC .
when using an asrock ion 330, should alsamixer have to be adjusted for hdmi audio out? or is the default fine?
Andyblac and frozenice, these issues are too complicated for this "newbie" thread. You might want to try "hciconfig hci0 reset" because the remote doesn't respond like it should.
It should do stuff like:
bluetoothd[3493]: Incoming connection on PSM 19
bluetoothd[3493]: ps3remote_event: Passed key 106:1
bluetoothd[3493]: ps3remote_event: Passed key 106:0
bluetoothd[3493]: ps3remote_event: Passed key 103:1
bluetoothd[3493]: ps3remote_event: Passed key 103:0
Anyway, I'd like to refer you guys to
this thread, which is more ended to technical users.
Good luck,
Dennis
p.s: Andy, you don't need lirc.
ThEgOg Wrote:when using an asrock ion 330, should alsamixer have to be adjusted for hdmi audio out? or is the default fine?
Alsamixer doesnt need to be edited for hdmi out, you just have to make sure all outputs are enabled and have volume. The out/through-put devices have to be set to hdmi though. I've had some reports that this depends on your receiver...
Be sure to read this thread and the one for the asrock ion 330:
http://forum.xbmc.org/showthread.php?tid=52460&page=36
G500 Wrote:install Appel move plugin and I-player if you can help that would be cool thanks again Dennis
Just check their respective threads for installation. I might add them to the script sometime...
flxfxp Wrote:Alsamixer doesnt need to be edited for hdmi out, you just have to make sure all outputs are enabled and have volume. The out/through-put devices have to be set to hdmi though. I've had some reports that this depends on your receiver...
Be sure to read this thread and the one for the asrock ion 330: http://forum.xbmc.org/showthread.php?tid=52460&page=36
i've fully formatted and reinstalled it 4 times now, followed your guide to the letter, got everything set as it should be, rebooted god knows how many times and still no hdmi audio
i'm begining to think it is be my onkyo receiver thats the problem, i had problems last year when i built a htpc that had hdmi out, all to do with the "handshake" between the two or something along those lines.
its really frustrating as i've got my movies set up and it all looks amazing, just no sound:confused2:
thanks for the help anyway mate
I have installed the script twice on my ubuntu box. I have a 865g integrated card. For some reason when I install the script it puts my box in a loop and it keeps crashing and I have to install all over again.
I cant get passed the 1st option of installing the stable version. Question what driver should I pick as my card is not nvidia when it asked me to pick on the initial install?
rflores2323 Wrote:I have installed the script twice on my ubuntu box. I have a 865g integrated card. For some reason when I install the script it puts my box in a loop and it keeps crashing and I have to install all over again.
the script currently only supports nvidia chipsets, sorry :-(
ThEgOg Wrote:i've fully formatted and reinstalled it 4 times now, followed your guide to the letter, got everything set as it should be, rebooted god knows how many times and still no hdmi audio
I assume you're using a asrock ion330? I would suggest to try other audio hardware, it works fine with my receiver
flxfxp Wrote:I assume you're using a asrock ion330? I would suggest to try other audio hardware, it works fine with my receiver
yes using asrock ion 330, i think i've ruled out my reciever by trying on a friends tv directly into one of the hdmi ports and still no audio:confused2:
not sure what else i can try really, do you think i should try installing live on a usb stick to see if that works?
or is there anyway i can check the hdmi port itself isn't faulty?
when you plugged it directly into ur friends tv, did you enable downmix multichannel? also untick dts and dolby. Thats the only way i get audio from my tv via hdmi.
cheers.
