Full Version: [LINUX] XBMScript - Easy installation for Ubuntu Jaunty Jackalope (9.04)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37
flxfxp Wrote:Did you reboot? check to make sure the keys are coming through correctly. kill the bluetooth deamon by doing "sudo killall bluetoothd" and start it manually with debug by doing "sudo bluetoothd -nd"
Let me know of the results.
I have the same situation, remote was added but no responce from it then. sudo bluetoothd -nd results:
login as: xbmc
[email protected]'s password:
Linux XBMCLive 2.6.28-11-generic #42-Ubuntu SMP Fri Apr 17 01:57:59 UTC 2009 i686
The programs included with the Ubuntu system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Ubuntu comes with ABSOLUTELY NO WARRANTY, to the extent permitted by
applicable law.
To access official Ubuntu documentation, please visit:
http://help.ubuntu.com/
Last login: Wed Oct 14 00:30:19 2009 from 192.168.0.101
(T: XBMCLive)xbmc@XBMCLive:~$ sudo ./xbmscript.sh
mkdir: cannot create directory `/home/xbmc/xbmscriptlogs': File exists
Status: Welcome! IP: 192.168.0.103
Author: Dennis - http://flx.me/xbmscript
              XBMScript
         Version: 2009-10-02
         !EXECUTE WITH SUDO!
    1.  Install XBMC Stable
    2.  Install XBMC SVN Version
    3.  Asrock ION 330 HDMI Audio
    4.  Setup FTP Server
    5.  Setup Samba (Windows File Sharing)
    6.  Setup Remote Control
    7.  Edit Skin Choices
    8.  Update Entire Sytem
    9.  Update XBMScript
    10. XBMScript Changelog
    11. XBMScript Troubleshooting
    12.  Exit
6
    Please Select Your Remote
    1.  Xbox DVD Remote
    2.  PS3 Bluetooth Remote
    3.  Generic Infrared Remote
    x.  Back
2
    What would you like to do?
    1.  Install PS3 Remote software
    2.  Add new PS3 Remote
    3.  List Devices
    4.  Delete Devices
    x.  Back
3
Devices:
Searching for devices, please wait...
Found:
1: 00:22:66:FE:57:3D [Unknown]
Select the device you wish to add [1]: ^C
    3.  List Devices
    4.  Delete Devices
    x.  Back
^C
(T: XBMCLive)xbmc@XBMCLive:~$ sudo killall bluetoothd
(T: XBMCLive)xbmc@XBMCLive:~$ sudo bluetoothd -nd
bluetoothd[3092]: Bluetooth daemon 4.54
bluetoothd[3092]: Enabling debug information
bluetoothd[3092]: parsing main.conf
bluetoothd[3092]: discovto=0
bluetoothd[3092]: pairto=0
bluetoothd[3092]: pageto=8192
bluetoothd[3092]: name=%h-%d
bluetoothd[3092]: class=0x000100
bluetoothd[3092]: discov_interval=0
bluetoothd[3092]: Key file does not have key 'DeviceID'
bluetoothd[3092]: Starting SDP server
bluetoothd[3092]: Loading builtin plugins
bluetoothd[3092]: Loading audio plugin
bluetoothd[3092]: Loading input plugin
bluetoothd[3092]: Loading serial plugin
bluetoothd[3092]: Loading network plugin
bluetoothd[3092]: Loading service plugin
bluetoothd[3092]: Loading hciops plugin
bluetoothd[3092]: Loading hal plugin
bluetoothd[3092]: Loading storage plugin
bluetoothd[3092]: Loading plugins /usr/local/lib/bluetooth/plugins
bluetoothd[3092]: register_interface: path /org/bluez/3092/any
bluetoothd[3092]: Registered interface org.bluez.Service on path /org/bluez/3092/any
bluetoothd[3092]: Parsing /etc/bluetooth/network.conf failed: No such file or directory
bluetoothd[3092]: Config options: InterfacePrefix=bnep%d, PANU_Script=(null), GN_Script=(null), NAP_Script=(null), GN_Interface=pan0, NAP_Interface=pan1, Security=true
bluetoothd[3092]: bridge pan0 created
bluetoothd[3092]: Parsing /etc/bluetooth/input.conf failed: No such file or directory
bluetoothd[3092]: Parsing /etc/bluetooth/audio.conf failed: No such file or directory
bluetoothd[3092]: Unix socket created: 9
bluetoothd[3092]: Telephony plugin initialized
bluetoothd[3092]: HFP AG features: "Ability to reject a call" "Enhanced call status" "Extended Error Result Codes"
bluetoothd[3092]: HCI dev 0 registered
bluetoothd[3092]: child 3097 forked
bluetoothd[3092]: btd_adapter_ref(0xb8e5e600): ref=1
bluetoothd[3092]: Failed to open RFKILL control device
bluetoothd[3092]: Entering main loop
bluetoothd[3092]: child 3097 exited
bluetoothd[3092]: HCI dev 0 up
bluetoothd[3092]: Starting security manager 0
bluetoothd[3092]: Changing Major/Minor class to 0x000104
bluetoothd[3092]: register_interface: path /org/bluez/3092/hci0
bluetoothd[3092]: Registered interface org.bluez.Service on path /org/bluez/3092/hci0
bluetoothd[3092]: network_server_probe: path /org/bluez/3092/hci0
bluetoothd[3092]: btd_adapter_ref(0xb8e5e600): ref=2
bluetoothd[3092]: Adding record with handle 0x10000
bluetoothd[3092]: Record pattern UUID 0000000f-0000-1000-8000-00805f9
bluetoothd[3092]: Record pattern UUID 00000100-0000-1000-8000-00805f9
bluetoothd[3092]: Record pattern UUID 00001002-0000-1000-8000-00805f9
bluetoothd[3092]: Record pattern UUID 00001115-0000-1000-8000-00805f9
bluetoothd[3092]: register_server_record: got record id 0x10000
bluetoothd[3092]: Registered interface org.bluez.NetworkPeer on path /org/bluez/3092/hci0
bluetoothd[3092]: Adding record with handle 0x10001
bluetoothd[3092]: Record pattern UUID 00001117-0000-1000-8000-00805f9
bluetoothd[3092]: register_server_record: got record id 0x10001
bluetoothd[3092]: Registered interface org.bluez.NetworkHub on path /org/bluez/3092/hci0
bluetoothd[3092]: Adding record with handle 0x10002
bluetoothd[3092]: Record pattern UUID 00001116-0000-1000-8000-00805f9
bluetoothd[3092]: register_server_record: got record id 0x10002
bluetoothd[3092]: Registered interface org.bluez.NetworkRouter on path /org/bluez/3092/hci0
bluetoothd[3092]: proxy_probe: path /org/bluez/3092/hci0
bluetoothd[3092]: btd_adapter_ref(0xb8e5e600): ref=3
bluetoothd[3092]: Registered interface org.bluez.SerialProxyManager on path /org/bluez/3092/hci0
bluetoothd[3092]: Parsing /etc/bluetooth/serial.conf failed: No such file or directory
bluetoothd[3092]: btd_adapter_ref(0xb8e5e600): ref=4
bluetoothd[3092]: headset_server_probe: path /org/bluez/3092/hci0
bluetoothd[3092]: btd_adapter_ref(0xb8e5e600): ref=5
bluetoothd[3092]: audio_adapter_ref(0xb8e5fc20): ref=1
bluetoothd[3092]: Adding record with handle 0x10003
bluetoothd[3092]: Record pattern UUID 00000003-0000-1000-8000-00805f9
bluetoothd[3092]: Record pattern UUID 00001108-0000-1000-8000-00805f9
bluetoothd[3092]: Record pattern UUID 00001112-0000-1000-8000-00805f9
bluetoothd[3092]: Record pattern UUID 00001203-0000-1000-8000-00805f9
bluetoothd[3092]: Adding record with handle 0x10004
bluetoothd[3092]: Record pattern UUID 0000111e-0000-1000-8000-00805f9
bluetoothd[3092]: Record pattern UUID 0000111f-0000-1000-8000-00805f9
bluetoothd[3092]: a2dp_server_probe: path /org/bluez/3092/hci0
bluetoothd[3092]: audio_adapter_ref(0xb8e5fc20): ref=2
bluetoothd[3092]: SEP 0xb8e60da0 registered: type:0 codec:0 seid:1
bluetoothd[3092]: Adding record with handle 0x10005
bluetoothd[3092]: Record pattern UUID 00000019-0000-1000-8000-00805f9
bluetoothd[3092]: Record pattern UUID 0000110a-0000-1000-8000-00805f9
bluetoothd[3092]: Record pattern UUID 0000110d-0000-1000-8000-00805f9
bluetoothd[3092]: avrcp_server_probe: path /org/bluez/3092/hci0
bluetoothd[3092]: audio_adapter_ref(0xb8e5fc20): ref=3
bluetoothd[3092]: Adding record with handle 0x10006
bluetoothd[3092]: Record pattern UUID 00000017-0000-1000-8000-00805f9
bluetoothd[3092]: Record pattern UUID 0000110c-0000-1000-8000-00805f9
bluetoothd[3092]: Record pattern UUID 0000110e-0000-1000-8000-00805f9
bluetoothd[3092]: Adding record with handle 0x10007
bluetoothd[3092]: Creating device /org/bluez/3092/hci0/dev_00_1E_3D_14_C6_67
bluetoothd[3092]: btd_device_ref(0xb8e61e60): ref=1
bluetoothd[3092]: Probe drivers for /org/bluez/3092/hci0/dev_00_1E_3D_14_C6_67
bluetoothd[3092]: hid_device_probe: path /org/bluez/3092/hci0/dev_00_1E_3D_14_C6_67
bluetoothd[3092]: btd_device_ref(0xb8e61e60): ref=2
bluetoothd[3092]: Registered interface org.bluez.Input on path /org/bluez/3092/hci0/dev_00_1E_3D_14_C6_67
bluetoothd[3092]: Adapter /org/bluez/3092/hci0 has been enabled
bluetoothd[3092]: Computer is classified as desktop
bluetoothd[3092]: Setting 0x000104 for major/minor device class
If you do ps3_pair.py -list while bluetoothd is running, does it show the device?
flxfxp Wrote:If you do ps3_pair.py -list while bluetoothd is running, does it show the device?
Have done installation once again from scratch. It say no devices found while do not let me pair it one more time (Failed. Device already exist)
(T: XBMCLive)xbmc@XBMCLive:~$ bluetoothd
(T: XBMCLive)xbmc@XBMCLive:~$ sudo python ps3_pair.py -list
Found:
No devices found
P.S. Bluetoothd need to be started manually after using XBMCScript? Nevertheless killing it via "sudo killall bluetoothd" and starting it via "sudo bluetothd" do not change the picture.
login as: xbmc
applicable law.
Last login: Wed Oct 14 10:32:43 2009 from 192.168.0.101
Found:
No devices found
(T: XBMCLive)xbmc@XBMCLive:~$ modprobe uinput
(T: XBMCLive)xbmc@XBMCLive:~$ sudo /usr/local/sbin/bluetoothd
Found:
No devices found
Found:
1: 00:1E:3D:14:C6:67 [BD Remote Control] [color=blue]<-this time i tried to pair it pushing enter + start[/color]
Select the device you wish to add [1]: 1
Registering device...  Failed ( Device already exists )
(T: XBMCLive)xbmc@XBMCLive:~$ sudo python ps3_pair.py -list [color=blue]<- after 15 seconds not using pairing[/color]
Found:
(T: XBMCLive)xbmc@XBMCLive:~$ sudo python ps3_pair.py -list [color=blue]<- after another 15 seconds still not using pairing[/color]
Found:
No devices found
I'm completely lost... Sad
Hexus Wrote:
login as: xbmc
applicable law.
Found:
No devices found
Found:
No devices found
Found:
Found:
Found:
No devices found
You should use --list, not -list
flxfxp Wrote:You should use --list, not -list
Dennis, unfortunately result is the same, thru --list or thru XBMScript list BD devices option. No devices found Sad I've lost where to look for errors then...
Question - is original bluez package need to be installed prior using XBMScript? I've tried this also but with mistakes like this. Also maybe XBMCLive Ubuntu package simply cannot be configured thru XBMScript way?
Are you using XBMCLive? In that case I can't guarantee or know if it works. You're on your own on that one. Be sure that EVERYTHING of the original bluez package is gone before installing bluez-patched.
Hmm....so how is this different from http://forum.xbmc.org/showthread.php?tid=55282 - it does the same, right? Which one to use?
I got everything working except for being able to suspend and since I can't get this to work, also to start again via the remote.
I have the Windows MCE Remote + IR receiver 1.0A and it works fine for navigating. I think the problem may be Linux related as suspend/hibernate doesn't work either when setting the Shutdown button in XBMC to either of these and directly pressing the Shutdown button in XBMC. All that happens is that the screen goes black for a few seconds and then XBMC restarts itself again.
The only thing that works is Shutdown when setting Shutdown Function to Shutdown in Settings in XBMC. This turns the AsRock off, but I can't start it via the remote when doing that.
How can I enable suspend functionality?
EDIT: Just tried XBMC Live where it works fine. What can the difference be?
Tried redoing it and removing all partitions and now it works! Now I just need to find a more quiet system than this damn high pitched Asrock :-) Hoping the new Asus EEE EB1012 will be quiet and that this script will work on it as well.
Could you add MiniMeedia to the skins?
http://xboxmediacenter.svn.sourceforge.n...iniMeedia/
Where can I find the folder to put in plugins and themes on this ubuntu install? I installed the Gnome Desktop Manager (from which I'm typing right now Smile ) but I can seem to find the right folder.
/usr/share/xbmc or ~/.xbmc/
I'm currently very busy with work but when I have the time I'll work on additions such as new skins and scripts.
Same probmems to initiate the PS3 remote...
Please fill in the MAC Address of the device you would like removed:
00:1E:3D:1A:0B:9D
ERROR:dbus.proxies:Introspect error on org.bluez:/: dbus.exceptions.DBusException: org.freedesktop.DBus.Error.ServiceUnknown: The name org.bluez was not provided by any .service files
  File "ps3_pair.py", line 90, in <module>
    Main()
  File "ps3_pair.py", line 18, in __init__
    self.adapter = self.manager.GetAdapter()
  File "/home/xbmc/bluez/utils.py", line 28, in warp
    raise errors.parse_dbus_error(exception)
bluez.errors.DBusServiceUnknownError: The name org.bluez was not provided by any .service files
bluetoothd: no process killed
xbmc@iona:~$ hciconfig
hci0:   Type: USB
        BD Address: 00:19:0E:03:67:D9 ACL MTU: 1021:8 SCO MTU: 64:1
        UP RUNNING PSCAN
        RX bytes:1007 acl:0 sco:0 events:33 errors:0
        TX bytes:1103 acl:0 sco:0 commands:33 errors:0
xbmc@iona:~$ isusb
-bash: isusb: command not found
xbmc@iona:~$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 004: ID 147a:e017 Formosa Industrial Computing, Inc.
Bus 002 Device 003: ID 04fc:05d8 Sunplus Technology Co., Ltd
Bus 002 Device 007: ID 050d:016a Belkin Components
Bus 002 Device 006: ID 0a5c:4503 Broadcom Corp.
Bus 002 Device 005: ID 0a5c:4502 Broadcom Corp.
Bus 002 Device 002: ID 0a5c:4500 Broadcom Corp.
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Thanks for help !
I don't see you bluetooth device in that list, be sure that its loaded. If you can't figure it out, ask the ubuntuforum for help.
Regards,
Dennis
flxfxp Wrote:I don't see you bluetooth device in that list, be sure that its loaded. If you can't figure it out, ask the ubuntuforum for help.
Regards,
Dennis
The bluetooth adapter is the Bekin line...
Lionel
