Well system is faulty no HDMI output at all, that however doent explain all other failures =(
Cant get FTP server sorted at all, tomorrow I'll get a replacement machine and see if it was machine or pebkac.
I wanted to add some info as I looked at the script and read somemore about 24hz setup and hwcursor again I had to perform these manually like I did as part of a non scripted install since the code did not execute or put out any errors or warnings
#--[HW cursor fix
sudo sed -i '40i\ Option "HWCursor" "False"' /etc/X11/xorg.conf
#--[ENABLE 1080p 24Hz (screen section)
sudo sed -i '50i\ Option "DynamicTwinView" "False"' /etc/X11/xorg.conf
sudo sed -i '50i\ Option "FlatPanelProperties" "Scaling = Native"' /etc/X11/xorg.conf
I would not presume to go adding logging support for those options or add numerical menu choice lets face it I see the code but its just too much for my old brain I suppose I would rather see flxfxp messing with his script instead of me ruining it really.
Theres a ton of hidden power for this script that should imho be added with descriptive options. I will make sure flxfxp has some xmas
beer and bacon for looking at these things and sorting it out appropriately, I would like to see this script working perfectly to update and remove the grub options from bootup on a normal xbmcLive install where it uses legacy grub though it is well hidden.
Same for other code that may actually run as part of other installs that would benefit a normal upgrade if u just wanted to add it to a XBMCLive install like nvidia 190.42 drivers. (as well as other code snippets)
these are the points I suggest be improved.
> Better FTP server Setup support (e.g. Server Messages, ssl creation etc.)
> Added options to support Existing code (Alsa Upgrades, hwcursor fixes, nvidia drivers upgrade (in case someone is using existing XBMCLive setup to upgrade to svn from there) 24hz Fixes etc.
> Uncomment SVN Repo Intaller and add option to set it up individually from other options.
> GRUB2 Fixes to allow no Grub Boot similar to XBMCLive Setup -
https://wiki.ubuntu.com/Grub2
> XBMC Fixes to remove static XBMC leaving only the custom animated uSplash
> Add option to support which uSplash artwork gets installed
- e.g.
sudo apt-get install usplash-theme-xbmc-*
sudo update-alternatives --config usplash-artwork.so
sudo update-initramfs -u
Though this code is in script user never gets prompted for which one gets selected and installed the default is se for the spinner as the script chooses for you.
> Support for hardware sensors set up & configuration -
http://www.lm-sensors.org/wiki/iwizard/ManualInstall
Me hopes the author reads these posts and gives sum feedback addressing the ftp server config to ensure all the configurable fields are processed by script passing it to config like the welcome message and ssl options and whatnot.
Im not holding my breath though just my thoughts on how to improve something great making it more flexible and modular perhaps if each area of script would have a explanation what the code does users like the rest of us could modify and add to script a bit easier. For however complete this is I still find I have to dip into manual config. Good work though.
