Full Version: Problem locating default skin (PM3.HD)
I recently installed the opensubtitles-osd plugin. But I am having difficulties applying the skin hack referred to.
The instructions for applying the hack says that a copule of files should be replaced in skin folder of the active skin. My problem is that my skin folder is completely empty and I cannot seem to find the location of the default skin either. I am using the default PM3.HD skin and have not installed any others either.
Does anyone have any hints for me?
I have the exact same problem and would be glad if someone could shed some light on this!
wild_oscar Wrote:I have the exact same problem and would be glad if someone could shed some light on this!
if you are using the latest SVN > 23729, you dont need the skin hack, you need to enable subtitle button and set the path to scripts default.py
it would help if you tell us what platform you are on and XBMC version so that we can tell you where to look for.
Zeljko
