Hello
I have an Asrock nettop 330 ION box where i have ubuntu 9.04 and xbmc. (I had followed this guide to install xbmc:
http://www.xbmc.org/forum/showthread.php?t=54705
Yesterday i updated my system and today i want to start xbmc. But i got an error when i try to start xbmc.
"Error
XBMC needs hardware accelerated OpenGL rendering. Install an appropirate graphic driver".
Anyone knows how to solve this ?
(sorry for my english and btw im new to linux)
I had this issue to and after I verified I had the correct video drivers installed, I had to restart the x server.
To do that (the easy way) just go to the shutdown button, but LOG OFF, then log back in.
Should work after that. (For some reason rebooting doesn't do it properly)
#Grunyan thank you
I tried to log off and then log in. After that the error disappears but when i start XBMC I see the black screen with the text XBMC and then it goes back to the desktop ? :-S
zarn Wrote:#Grunyan thank you
By the sounds of it you're trying to install Nvidia drivers under x64?
If so, try from a commandline:
sudo sh NVIDIA-*.run --compat32-prefix=/usr --compat32-libdir=lib32 --compat32-chroot=
If you're getting errors saying you're on a modular build of X11 and can not find the directories, blah blah, include this into the install:
--x-module-path=/usr/lib/xorg/modules --x-library-path=/usr/lib
#Gryph thanks
No I have installed a x32 version of Ubuntu desktop and a x32 Nvidia driver. My problem is XBMC. When i try to start it, it shows me the black screen with the XBMC logo and then it goes back to the desktop? maybe it has something to do with the Nvidia driver ?
#Maxim thanks
In my home folder i found alot of xbmc crash logs.
I have pasted the last crash log here
http://pastebin.com/m6741cadb
Maybe someone can see what is wrong ?
#Maxim
Thank you very much :-D
Your link solved the problem. XBMC works fine now and I can see my movies again
