Full Version: Transparency 2.0 with Rev22928
Hi!
I've used xbmc updater to install the latest rev version, 22928.
This works like a charm, but now I'd like to use the Transparency skin.
When I select the skin it says:
Incompatible skin. We require skins of version 2.10 or higher.
What went wrong? Am I missing something here? What version are they talking about? What should be version 2.10 or higer?
Thanx in advance!
check if the skin is in
...skin/transparency and not in ...skin/transparency/transparency
omg.. I'm such a dork...
I must say the error message was a bit descriptive.. but kudo's for xbs08!
I've unrarred the skin and placed in the skin folder. I didn't check the content though... Smile
LOL, I did this the first time too. Ronie had to set me straight as it never occured to me that it would unrare like that.
Remmie Wrote:Hi!
please be aware you will bump into some issues when using a xbmc revision above 22528.
i've also installed 22928 just for testing purposes and it's far from stable.
