Hi all,
At the moment if i want to add stuff to the library i can see two methods..
select file/folder and scan content
or
leave the option on that makes xbmc scan for new content on startup
Both work fine, but both i think have disadvantages.
If i have to scan manually sort of speak i have to go out of library mode and scan movies or series folders manually (don't have music so thats not a prob),
then return to library mode and go back to the views i prefer (e.g. all movies sorted by title)
or
f i leave the option on to search for new content on startup it scans on every startup.
However i tend to add stuff in big chunks, i.e might add 10 movies and 10 different episodes once a fortnight in one go, sometimes more often, sometimes less often
My idea is a script that will simply scan all folders that are linked when used.
It would be great if this could able be added to skins as a button or something?
Or just linked into favourites if preferred.
Would this script be possible in XBMC? :confused2:
Thanks all, never tried scripting so may give it a go myself if get chance.
uhrr. executebuiltin(updatelibrary(video))
yes. totally doable.
spiff Wrote:uhrr. executebuiltin(updatelibrary(video))
Thanks, i'm gona have a go at writing this i think.
Looks just the right size of project for my first go at scripting
Quote:If i have to scan manually sort of speak i have to go out of library mode and scan movies or series folders manually (don't have music so thats not a prob),
You don't really have to leave the library to do this.
Inside the library in any view>context menu>update library.
In any case unless you want it to be smarter about when it scans, scripting is unnecessary.
rwparris2 Wrote:You don't really have to leave the library to do this.
Your right! problem solved, not spotted that.
Would be good to just update everything from home screen/fav screen, but won't bug me as much now!
Hi to all,
I've upgraded my xbmc to latest svn, before that I've used two scripts to auto update my library but now seems not to work.
The scripts are in "C:\Program Files (x86)\XBMC\scripts" folder and are the following:
autoexec.py
import xbmc, xbmcgui
xbmc.executebuiltin('XBMC.AlarmClock( VideoLibraryUpdater, XBMC.RunScript(special://home/scripts/VideoLibraryUpdater.py),45,true)')
xbmc.executebuiltin('XBMC.UpdateLibrary(video)')
I found the scripts in this
post, how can I make these to work with the new addon system?
Thanks and sorry for my english
I am interested in this as well,
I have put all that in a skin.autoupdater format with addon.xml, but unsure how special:// path relates to it or if can be made auto-executable?
Cheers,
I'm just taking a guess here, but they should be in a script.autoupdater folder (I believe), and the name should be changed to default.py (again, I believe). Someone with some knowledge should be able to tell you for sure though.
Yep, had changed it into the script.* standard and have addon.xml file too.
I have 2 issues;
1. what will the new path be from "special://home/scripts/VideoLibraryUpdater.py"
2. how can I make the script auto-execute as before. making it default.py means i have to start it every time - deal breaker.
anyone? I doubt I am the only user that wants an automatic way of updating the library..
Ilia Wrote:anyone? I doubt I am the only user that wants an automatic way of updating the library..
No, you're not the only, please help us!!!
I'm an idiot at this stuff, but I don't think you need the special://path anymore. So
is now just
XBMC.RunScript(script.foo), or something similar to that I think
I got it working, here are the steps:
1. create a file called autoexec.py under xbmc/scripts/
PHP Code:
import time, os
time.sleep(5)
xbmc.executebuiltin("XBMC.RunScript(%s/default.py,-startup)" % ( os.path.join( os.getcwd(), "../addons/script.au/" )))
2. create 3 files with this content under xbmc/addons/script.au (au = autoupdate)
addon.xml
PHP Code:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<addon id="script.au"
name="Auto Updater"
version="1.0"
provider-name="forum">
<requires>
<import addon="xbmc.python" version="1.0"/>
</requires>
<extension point="xbmc.python.script"
library="default.py" />
<extension point="xbmc.addon.metadata">
<summary lang="en">Auto Updater script</summary>
<description lang="en">Auto Updater script</description>
<platform>all</platform>
</extension>
</addon>
default.py
PHP Code:
import xbmc, xbmcgui, os
command = "XBMC.RunScript(%s)" % ( os.path.join( os.getcwd(), "VideoLibraryUpdater.py" ) )
xbmc.executebuiltin( "AlarmClock(VideoLibraryUpdater,%s,45,true)" % ( command ) )
PHP Code:
Restart/Start xbmc and you should see Auto Updater in your list of addons/scripts - the script will also start on xbmc boot. Thats it.
Now the reason I created a "proper" script is that you can cancel the AlarmClock when you go to the addons/script and select the Auto Updater in xbmc.
Now,since I am a noob at python and xbmc scripting in general - I would love this to be cleaned up (possibly providing some settings screen) built into xbmc like recentlyupdated script for movies, so users can auto update they library!
enjoy!
Ilia
Great Ilia, I'll try it asap.
Thanks for your support
Ok, I created the folder scripts inside xbmc install folder ("C:\Program Files (x86)\XBMC\scripts") and putted inside the autoexec.py, I created the folder script.au inside the addon folder and putted inside the other two files, but seems that the autoexec.py isn't starting, if I manully start the script the library is updating, if not nothing happens!!!
Any idea
