Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
I often have this problem. Now I use tinymediamanager for the scraping of film and tv' series
Is tinymediamanager finding Italians metadata and is available for xbmc/raspberry as addon?
However I find myself very well with mymovies.it addon.
Tried this morning and all seems ok!
Thx
No, tinymediamanager is a stand-alone program. Yes it find italians metadata.
Thanks to both but I continue to use the mymovies.It addon, probably it was a temporary server problem...
Hello, first of all thanks for all the work you have done and shared.
I recently installed XBMC on my Raspberry (Raspbmc) and I enabled the scrapper MyMovies.it but I can't get any fanart (the info and posters are ok!).
I something wrong in the settings or is there still a problem?
I am a beginner and I do not know if and how I can configure XBMC to load only the fanart from imdb, for instance, and the other info from MyMovies.it ...
This issue happen with all films?
with some films it is normal...
try something like: Aliens, Avatar, etc..
Yes, with all films including Avatar.
Strange, I have tried now, and all seems works good.
In the "movie information" can you see the button "choose art", there are something there?
Yes, in the movies information I can see the option to choose the poster, fanart and another picture (I don't remember exactly the last one) but when I select the fanart no pics are present.
Thanks for help!
(2014-11-06, 15:36)muttley:bd Wrote: [ -> ]it's very strange...
try to see if you have enabled it: http://kodi.wiki/view/FanArt
What do you mean exactly? Under the settings of the scrapper or choosing the view type or... ?
I can't see any specific settings for the Fanart...
I don't what I mean
Maybe you could have disabled fanart in xbmc global setting.
And in the wiki is explained how to enable it
Another test is use universal scaper and see if it works
I'll check asap!
Thanks for your help!
Hi, I've a issue with MyMovies.it scraper: it works as expected except with a movie called "
Paz!".
It's a simple avi file and the title is in the mymovies.it database (see here:
http://www.mymovies.it/dizionario/recens...p?id=33787) but I can't get it scraped, even if I manually set the name Paz! when requested. The mymovies scraper plugin shows a list with some title but the title
Paz! is not present.
Here is my xbmc (debug enabled):
http://xbmclogs.com/show.php?id=353797
Cheers, Epg1
