2011-03-02, 21:16
2011-03-03, 17:54
Quote:Another one:
Madonna - Celebration
have you find the bug?
Very strange! The films you are reported not appear in internal research of mymovies.it.
If you make an internal search (by google) on mymovies, you get this page.
Also if you try: http://www.google.com/sitesearch/ (with mymovies.it).
If you search the same title on google, all work good...
I must try to change the search url, but it's very strange
the .nfo file,as i suggest you, work good?
ciao!
p.s. it's not a scraper bug...
2011-03-04, 21:10
New release available: here
...and soon on official xbmc repository!
Changelog:
- Change default films search url: http://www.google.it/search?q=film_name+...ymovies.it
- Fixed trailer problem. The first and only issue reported on http://code.google.com/p/mymovies-xbmc-scraper/issues/
- Fixed search problem. Reported here http://forum.xbmc.org/showpost.php?p=733...stcount=89
Ciao!
Changelog:
Ciao!
2011-03-05, 17:16
With new version ok for MADONNA..but nothing to do with START TREK VI Rotta verso l'ignoto....
aiuto...ciao
aiuto...ciao
2011-03-05, 17:43
2011-03-05, 17:48
sorry all ok...STAR TREK too thanks...
grazie 1000!!
...bu the icon? my scarper don't find your icon?
grazie 1000!!
2011-03-11, 15:02
muttley:bd Wrote:New release available: here
Changelog:
Ciao!
Hi guys,
i'm a newbie. Since 5 days ago mymovies scraper can't retrieve movie's info from the site anymore (i use muttley's v1.0 scraper).
Now how can i install the new reliese v1.1.1? I usually change the files mymovies.xml and mymovies.png in System/scraper/video folder, but doesn't work (XBMC not see any scraper mymovies). I' ve noticed that in this release there are several files and folders, WHERE I PUT THEM?
- XBMC 9.11 R26017 with mediastream skin -
THANKSSSS
PS= i ve already search in 'how to' thread but nothing found. hope this is the right place
2011-03-14, 23:32
hi, i have a question about this fantastic scraper.
i have a few films in high definition. now i downloaded some of them in 3d version (SBS). i would like to mantain both copy (HD and HD 3D SBS). is there a way to add in the name of the movie the string "3D" if it's in the filename?
excuse me for my bad english i'm trying to do this thing with a mysql script (i have the database in a mysql server)
2011-03-15, 12:20
darkdragon Wrote:Hi guys,
THANKSSSS
Update to last XBMC release 10.0 Dharma and use new addons features to install scraper from official repository.
Quote:i have a few films in high definition. now i downloaded some of them in 3d version (SBS). i would like to mantain both copy (HD and HD 3D SBS). is there a way to add in the name of the movie the string "3D" if it's in the filename?
sorry, but this is not possible for scraper, do you have to ask to developers.
2011-03-28, 14:11
New release available v1.1.2 here
Changelog:
- Fixed regex: rating and trailer
- Fixed url cache
Changelog:
- Fixed url cache
2011-04-11, 20:31
Muttley: thanks a lot, after installing XBMC I was wondering if someone made a good scraper for MyMovies.it and I found yours.
It's working fine...a little bit slow because I turned all the options on, but it's not your fault.
Keep up the good work.
2011-04-12, 10:06
You are wellcome!
..and thanks for support
2011-04-18, 10:36
I had seen the scraper is "marked broken" yesterday
...and it's correct because don't work
Who and how addons can be marked broken?
(i'm working on scraper...)
2011-04-18, 12:05
Users can't mark it as broken.
I did a test yesterday on all the scrapers in the repo myself and marked all broken which were not working (look at addon.xml to see how it is marked).
2011-04-18, 13:08
Quote:I did a test yesterday on all the scrapers in the repo myself and marked all broken which were not working (look at addon.xml to see how it is marked).
waooooo!! ...respect for your hard work!
thank ahead for my next SVN Pull...
