Full Version: Container.Content(Season) in DialogVideoInfo
Pages: 1 2
i'm trying to create separate layouts for tv-show and season level in the video info dialog, but xbmc doesn't seem to recognize Container.Content(Seasons) in DialogVideoInfo.xml
can this be added? or is there a reason why it's left out?
the reason for having different layouts is because most people are using banners for tv shows and posters for seasons.
ronie Wrote:i'm trying to create separate layouts for tv-show and season level in the video info dialog, but xbmc doesn't seem to recognize Container.Content(Season) in DialogVideoInfo.xml
should be Container.Content(seasons)
eumel Wrote:should be Container.Content(seasons)
regardless of my typo, it's not working ;-)
ronie Wrote:regardless of my typo, it's not working ;-)
oh excuse me, but sometimes there's just such typos are the tearing of hairWink
Longwinded I know but couldn't you use !Container.Content(tvshows) + !Container.Content(episodes) + !Container.Content(movies) if it's only seasons that's not playing ball?
Maybe you can do it with a trick?
In the season level view installs a button without textures with an ID and in the video info dialog query if it is visible.
i don't know if it work.
Hitcher Wrote:Longwinded I know but couldn't you use !Container.Content(tvshows) + !Container.Content(episodes) + !Container.Content(movies) if it's only seasons that's not playing ball?
thanx for the idea. tried it, but if i use !Container.Content(tvshows), it won't show up for seasons either.
thanx for the tips the both of you. i found something that works for me:
<visible>Container.Content(tvshows) + !StringCompare(Container.FolderPath,videodb://2/2/)</visible>
however, proper Container.Content(Seasons) support in dialogs would be better of course.
Note that technically we don't actually support season information in that dialog anyway. You'll notice you get the same info (other than the thumb??) as you do for doing an info lookup on the show item.
Given that there's no extra info for the season, IMO the better fix is to switch so that we display the tvshow thumb rather than the season thumb.
Your thoughts?
Cheers,
Jonathan
jmarshall Wrote:Note that technically we don't actually support season information in that dialog anyway. You'll notice you get the same info (other than the thumb??) as you do for doing an info lookup on the show item.
Your thoughts?
Cheers,
Jonathan
yep, agreed. just showing the tv show thumb at season level would be best.
jmarshall Wrote:Given that there's no extra info for the season
second thought...would it be worth implementing this?
from a user point of view, i would expect to see the number of episodes for the selected season in the dialog instead of the total number of seasons/episodes for the entire tv show.
i also would expect to be able to change the season thumb in the dialog and not the tv show thumb. this seems to be one of the things that confuses new users, they can use the dialog to change thumbs/fanart for just about everything, except for the season thumb. it's kinda hard to explain they'll have to use the context menu for this instead.
so for consistency across the skin/xbmc proper seasons support in dialog windows would be preferable imho.
Damnit! You and your entirely reasonable suggestions that make more work for us more devs :p
Mind adding a ticket to trac with the details so we don't forget Smile
Cheers,
Jonathan
the more work you do, the better xbmc will be. should be a comforting thought.
http://trac.xbmc.org/ticket/7198
Heh - thanks for the ticket!
i would love to see this implemented too. Smile
Pages: 1 2
