Full Version: textureradionofocus = radiobutton off texture
A small error in the wiki.
textureradionofocus is visible when the button is not turned on
textureradiofocus is visible when the button is turned on
Focus makes no difference
Quote:textureradiofocus
Specifies the image file which should be displayed for the radio button portion when it's the button is on and focused. This texture is positioned on the right of the button – it's positioned 24 pixels from the right edge of the button, and 8 pixels above the center vertically. As it's not displayed when the button is off, you may wish to have the off-state look rendered into the texturefocus and texturenofocus images.
textureradionofocus
Specifies the image file which should be displayed for the radio button portion when the button is on but does not have focus.
Thanks heaps - I've updated the manual, and we now support
<textureradioon>
<textureradiooff>
which are a little more obviously named!
Cheers,
Jonathan
