Can you add Weather windows in the main menu ?
Under the general menu is not confortable to use.
May I request this be optional if it does get added, possibly an option in the skin settings to turn it on.
wannabegt4 Wrote:May I request this be optional if it does get added, possibly an option in the skin settings to turn it on.
+1
AMAZING SKIN! The only one that works with fanart enabled and doesn't freeze up my Xbox! Thanks for all your hard work!
I would also LOVE to see weather as a main menu item on the home screen and then it display across the background
Weather has been implemented for the next version.
Has this now been added to the main menu, I can't find it? Thanks!
Next version is due in few days. Great job, scarfa, Rapier is my default skin. Can't wait the next version !
"Next version" is not 3.0/3.06? 'Cause I can't find anything in the options to activate it. I still have to go into general to find weather.
