2009-09-22, 23:57
2009-09-23, 00:44
2009-09-23, 01:09
Isn't this in the wiki?
2011-11-01, 21:51
it seems that the wiki has not tried out the latest xbmc, or the latest xbm,c has not read the wiki page...
let's say I have two files.
the first one is a double episode of a series, and the second file is the next episode after that.
So according to the wiki, i stick those in a folder named after the show, and then name the files like this:
S01E01-02 blabla.avi
S01E03 blub.avi
...and no matter what other variations of the stuff in the wiki I try, xbmc ALWAYS finds S01E03 as episode 2 of season 1....
HELP!!!
S01E03 blub.avi
HELP!!!
2011-11-01, 22:19
Have you checked the tvdb?
2011-11-01, 23:47
Lemmy Wrote:it seems that the wiki has not tried out the latest xbmc, or the latest xbm,c has not read the wiki page...
S01E03 blub.avi
HELP!!!
The following works perfectly for me
Stargate.Universe.S01E01E02.mkv
Stargate.Universe.S01E03.mkv
2013-05-30, 10:25
Naming Star Trek The Next Generation multi episode:
My current naming of part 1 & 2 of season 1:
sttng.S01E01E02.Encounter at Farpoint.mkv
gives me in XBMC
02. Encounter at Farpoint
What I wanted it to do is:
01. Encounter at Farpoint part 1
02. Encounter at Farpoint part 2
How to do that?
gives me in XBMC
How to do that?
2013-05-30, 12:01
2013-05-30, 12:13
This sometimes occurs when you select DVD order but then number them as Season / Episodes.
If you are using DVD order in your scraper settings be aware that the episode numbers are different: http://thetvdb.com/index.php?tab=season&...&order=dvd
2013-05-30, 12:20
I use therenamer to get the correct names for all my tv episodes.
For double episodes I use an underscore, which xbmc has no trouble with.
i.e. tvshowname.S01E01_02
Hope this helps
Hope this helps
2013-06-01, 23:11
Well, after using XBMC again I noticed that the tvdb scraper fixed it all by itself anyway, it was only the initial scan and presentation that gave me the weird presentation. So naming like this is still perfect:
using sttng a a series name returns me all episodes correctly without use of any other meta settings or preparation. I name my star trek as above:
sttng.S01E03.The Naked Now.mkv
sttng.S01E04.Code of Honor.mkv
and so on...
and so on...
