Full Version: [aTV] Help with Patchstick
Hi.
I just got my atv Big Grin yay. hehe.
But, as the big noob I am (I also blame the language!! since I'm from norway.. (A)) it dosnt work.
(Using windows vista 64bit)
This is what I do:
-Downloaded: atv-win-2.0
-Extracted the files into a folder on my dekstop.
-Got 2 files, 1 readme and one ...bat file? O_o
-Downloaded "2Z694-5660-029.dmg" from a site, this is also placed on the desktop.
-Started atv-win-2.0 and choosed the .dmg file and it created a .img file, named ... "Patch" Tongue
-Started "Usbit" and clicked on restore under my Kingstone USBstick.
THEN! I got a error, saying "Could not access the USB stick (Code 32!)"
So, help? plx Tongue
The UsbStick is FAT. If that matters?
-Thanks
can you try a different USB stick?
Often that is the problem.
-wes
Dont got one :S
A quick format solved it Big Grin yay.. hehe Tongue
It started on the atv, but its been stuck on "link encap: local loopback" and alot more info... Tongue
For about 10min now o0
Okay.
Can anyone help me?
I used the patchstick and after 20sec it says "link encap: local loopback" and something else.
After 15min or so, the screen goes black.
The aTV is still blinking..
99% of all patchstick problems are caused by incompatible usb sticks (I just made that up, really)
beg, borrow or steal a different usb stick
