Full Version: Do dialogs MyGameSaves and TrainerSettings still exist?
Do dialogs MyGameSaves and TrainerSettings still exist? Ive looked at the xbmc source code and cant see any references to them. How ever skins like PM3 HD etc still have the xml files....
So not sure if skins out of date or my eye sight is bad, or even both Nerd
Update:
While i remember whats the purpose for VideoOverlay.xml and MusicOverlay.xml as see they are normally empty now...
Those 2 and I think DialogBusy.xml, are only used on the Xbox.
They have been removed from Xperience mate. At this point XBOX may be out of the question for Xperience, BUT Ellipsis will be fine on XBOX and will probably be asked about if not there ...
greatant1337 Wrote:Those 2 and I think DialogBusy.xml, are only used on the Xbox.
what he said
cool thanks, will code then. Also any info your aware of regarding VideoOverlay.xml and MusicOverlay.xml?
They are still in use I just prefer not to use them Wink but they are just dialogs that show on screen all the time when music and videos are playing
Thanks, probably wont use them either unless i can think of something new to do with them.
