2009-09-23, 23:47
I have a weird bug where Video Plugins doesn't show. It has something to do with the MyVideos34.db file. If I have a fresh install and fresh MyVideos34.db file, then the Video Plugins button will not appear on the home screen. It appears as just a bottom line under Settings, but it's not able to be selected.
It's occurred on various builds of the Xbox ranging from r22968-23078 as well as my Windows installation which uses r22516. If I import an older MyVideos34.db file then everything works well, but I'm unable to delete movies or anything from the library and using Clean library does nothing.
Any ideas? Here's the log in case you see something I looked over.
I'll keep hunting to see what I can find, but I've been stumped for the past 2 hours looking. I narrowed it down to the file causing the error, but that's as far as I got. I tried Transparency! 2.0 and 2.01 and both did the same thing.
