Full Version: Feature Request All Branches
First off great work devs getting the svn whipped back into shape build wise Smile
2nd I have a feature request. If I build debug I get rUNKNOWN. If it shows unknown and somebody needs some help and you ask them which revision and they go and look and it only says unknown then it is not helping anyone.
Also if something mucks with the source and you build on *nix it adds a "M" next to the revision #.
Can we maybe add a new flag say "D" for debug so even if it IS debug it will show revision and that it is debug so you know you can ask for logs and dumps and what not.
If Build = "Release" then
revision = revision
elseIf Bulld = "Debug" then
revision = revision&"D
elseIf IsTouched = true then
revision = revisionM
Elseif Build = "Debug" AND IsTouched = "true" then
revision = revision&"DM
end if
not sure how to explain it any other way Sad And I know "submit a patch" and if I could I would, vbscript/asp I can do, C/C++/Python I can not Sad
Might this be possible? PAAALLLEEEEEZZZZ.
Craig
The "M" isn't added by us, it's tagged on by svnversion if the tree isn't clean. You shouldn't be releasing binaries where the sources are modified in any way. It's a GPL violation (unless of course these "modified" sources come with it). It would be in your best interest to check the binaries for this case before posting them on-line.
Embedding the configure flags has been on my list of shit to do for awhile now, then we could log them or dump them to the console, w/e. This would give us way more useful. Of course it doesn't help win32, but I wouldn't know (or particularly care Wink) where to start with that.
You can use the following preprocessor definitions to detect RELEASE and DEBUG mode in windows build of xbmc.
_DEBUG = Debug
NDEBUG = Release
#ifdef _DEBUG
    revision = "revision ( Debug )";
#else
    revision = "revision";
#endif
